FlashAir, a good solution for in-studio recording?
Solved by AkiraDaarkst,
5 minutes ago, Vadise said:I do not, which is why I am asking for opinions and experiences from other users here in this very topic. If you have that information, please share it. FlashAir supports a wide array of WiFi, B, G and N.
It'll be faster to take out the card, plug it into a card reader slot and offload the footage. Hell, you can even connect the camera to a capture card and record the video straight to the workstation, if the camera has a way of outputting a clean video signal.
32GB file transfer takes several minutes if not hours, still many times longer than using an USB 3.0 SD card reader.
