Eeey Guys!
So I've recently got a GTX 1080 (I already own it), which lead to me working my ass of to get my Custom-Built PC
But since I'm new to the Builders Community, I have no clue what I should get.
Thus I came to these Forums to ask what I should change about my Build;
These are a few things I want;
- Color-Scheme; Black, Silver Accents, RGB LED's
- Probably a Custom-Loop (My Friend has his own, he will help me)
- Great OC, but still quietness (English I know)
- Primarily for Gaming, Secundarily for 3D Rendering (CS:GO-ish) 2K-ish Video and 4K-ish Photo Editing (As a Hobby (Don't mind longer Render Times!))
- CD-DVD Drives (I know....)
- Budget of 2300 Euro's
- 21:9 Screen (Acer Predator X34, maybe, don't mind working some more for that,)
I came up with 2 Builds;
The Z170; http://de.pcpartpicker.com/list/hFb4gL (The 6700K will probz become the 7700K, if significantly better)
The X99; http://de.pcpartpicker.com/list/4HnkD8 (The Mobo costs about 300 Euro's)
They're roughly the same price
(I would also appreciate if u guys could give me ideas on the amount of storage)
Please tell me what u think of these Builds and tell me if u would Change anything
Thx!
(P.S. yes I know the Dominator Platinums and the M VIII Formula are overpriced, but I choose them because of the Color-Scheme)
https://linustechtips.com/topic/680145-first-build-help/
havent you posted this before?
1 minute ago, Ephy said:
Eeey Guys!
Thx!
CPU: Intel9-9900k 5.0GHz at 1.36v  | Cooling: Custom Loop | MOTHERBOARD: ASUS ROG Z370 Maximus X Hero | RAM: CORSAIR 32GB DDR4-3200 VENGEANCE PRO RGB  | GPU: Nvidia RTX 2080Ti | PSU: CORSAIR RM850X + Cablemod modflex white cables | BOOT DRIVE: 250GB SSD Samsung 850 evo | STORAGE: 7.75TB | CASE: Fractal Design Define R6 BLackout | Display: SAMSUNG OLED 34 UW | Keyboard: HyperX Alloy elite RGB |  Mouse: Corsair M65 PRO RGB | OS: Windows 10 Pro | Phone: iPhone 11 Pro Max 256GB
https://linustechtips.com/topic/680145-first-build-help/#findComment-8747703
As I said before, 750W is overkill, 500W is enough. Dont get the founders edition, higher cost for worse temps. Any reason you are reposting it?
Please quote our replys so we get a notification and can reply easily. Never cheap out on a PSU, or I will come to watch the fireworks.
PSU Tier List
My specs
PC:
CPU: Intel Core i5-6600K @4.8GHz
CPU Cooler: Noctua NH-U14S
Motherboard:  ASUS Maximus VIII Hero
GPU: Zotac AMP Extreme 1070 @ 2114Mhz
Memory: Corsair Vengeance LPX 16GB (2 x 8GB) DDR4-2400
Storage: Samsung 850 EVO-Series 500GB
Storage: Western Digital Caviar Blue 1TB
Case: Cooler Master MasterCase Pro 5
Power Supply: EVGA 750W G2
Peripherals
Keyboard: Corsair K70 LUX Browns
Mouse: Logitech G502
Headphones: Kingston HyperX Cloud Revolver
Monitor: U2713M @ 75Hz
https://linustechtips.com/topic/680145-first-build-help/#findComment-8747711
5 minutes ago, Ephy said:
Eeey Guys!
https://linustechtips.com/topic/680145-first-build-help/#findComment-8747717
CPU: Intel Core i7-6800K 3.4GHz 6-Core Processor  (€428.11 @ Mindfactory)
Motherboard: Asus X99-E ATX LGA2011-3 Motherboard  (€232.97 @ Amazon Deutschland)
Memory: G.Skill Ripjaws V Series 32GB (2 x 16GB) DDR4-3200 Memory  (€183.99 @ Mindfactory)
Storage: Samsung 850 EVO-Series 500GB 2.5" Solid State Drive  (€162.46 @ Mindfactory)
Video Card: NVIDIA GeForce GTX 1080 8GB Founders Edition Video Card
Case: be quiet! DARK BASE PRO 900 | SILVER ATX Full Tower Case  (€215.84 @ Mindfactory)
Power Supply: Super Flower Leadex Gold 750W 80+ Gold Certified Fully-Modular ATX Power Supply  (€126.08 @ Mindfactory)
Operating System: Microsoft Windows 10 Home OEM 64-bit
Total: €1349.45
Generated by PCPartPicker 2016-10-24 13:40 CEST+0200
https://linustechtips.com/topic/680145-first-build-help/#findComment-8747722
Just now, herman mcpootis said:
He reposted it to say that? I already thought that was clearly implied in the last post. If not, a simple edit would have done.
PSU Tier List
My specs
PC:
Peripherals
https://linustechtips.com/topic/680145-first-build-help/#findComment-8747726
You should add a hard drive into this build somewhere. If youre gonna do video editing, 500gb might not cut it. You could add a 1-4tb drive in for pretty cheap. You could also bring that 500gb ssd down to a 480gb ssd. That way youd have more budget for a hdd. Just my opinion tho. Badass rig dude
https://linustechtips.com/topic/680145-first-build-help/#findComment-8747762
Umm i dont know anything about water cooling but since your planning to have one i might suggest research on youtube or google about water cooling and its maintenance your friend wont be always there to help you about it, a single leak may become your worse nightmare, but if you already made your own research about it good for you
https://linustechtips.com/topic/680145-first-build-help/#findComment-8747776
If you can, I would spring for 256gb Samsung 950 pro NVMe SSD.  Just installed one a friends computer, and holy shit, its awesome. And for mass storage id get a Western Digital 4TB Black HDD
https://linustechtips.com/topic/680145-first-build-help/#findComment-8747789
True, but those NVMe SSD's are quite expensive!
https://linustechtips.com/topic/680145-first-build-help/#findComment-8752932
I did some research, but should I go for a AIO then?
https://linustechtips.com/topic/680145-first-build-help/#findComment-8752935
I thought I should get the 750W, because my Rig would require 640W when I 2 Way-SLI
https://linustechtips.com/topic/680145-first-build-help/#findComment-8753050
Should I get the Kingston Predator PCI-e SSD 240GB's
https://linustechtips.com/topic/680145-first-build-help/#findComment-8753072
2 minutes ago, Ctown0812 said:
The predator is only  PCIe 2.0, so Its not nearly as fast as the Samsung 950 at PCIe 3.0.  But, it still a significant upgrade to a SATA drive.
Oh u meant the NVMe 950bPro, that one is still quiet affordable, 512GB for about 300 Euro, I could throw in a 3TB HDD for 100 more Euro's should be enough
https://linustechtips.com/topic/680145-first-build-help/#findComment-8753140
