Building an offfice PC
Go to solution Solved by Cereal5,
CPU: Intel Core i5-6500 3.2GHz Quad-Core Processor  ($195.79 @ OutletPC)
Motherboard: Asus H110M-A Micro ATX LGA1151 Motherboard  ($58.99 @ SuperBiiz)
Memory: Corsair Vengeance LPX 16GB (2 x 8GB) DDR4-2133 Memory  ($73.99 @ Newegg)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($49.49 @ OutletPC)
Video Card: PowerColor Radeon RX 460 4GB Red Dragon Video Card  ($128.99 @ SuperBiiz)
Case: NZXT Source 210 Elite (Black) ATX Mid Tower Case  ($45.99 @ SuperBiiz)
Power Supply: Corsair CXM 450W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($45.00 @ Newegg)
Total: $598.24
Generated by PCPartPicker 2016-10-23 20:43 EDT-0400
Here's my two cents. RX 460 4GB for the gamezzz, the i5 will do well in work and productivity(and you save $20 for only 100MHz off the clock speed), and honestly the PSU @gtx1060=value Mentioned isn't terrible, just know not to put too much nice hardware behind it before upgrading
I'm looking to build a PC that can function as a home office. Something that can load spreadsheets quickly and store lots of data, and yes, I want it to play games on it relatively well.
1. Price: I'm looking to spend around $0-$600ish dollars on this build, but cheaper is preffered.
2. Aim: Like I said, this is going to be an office PC. I want something that can run office programs and, this is a big one, Adobe Photoshop and Premiere. If at all possible I would also like it to run games, such as Diablo III at a decent framerate. (I don't need anything crazy for gaming, though, because Diablo III is probably the most GPU demanding game I will ever play)
[Skipping step three because I already have a good monitor]
4. Peripherals: I already have a mouse and keyboard on stand-by, but suggestions would be nice :), I also want Windows 10
5. Why I'm Upgrading: I currently use a pre-built Dell PC (The Inspiron 660) and it runs like a mushy potato. It's slow and it gets very hot, the parts are very old and it's just time to replace it.
I went ahead and created a PC with those specifications, feedback and ideas are welcome.
Case: Corsair Carbide Series 200R [ATX Mid-Tower]
Motherboard: GIGABYTE GA-Z170X-UD5 [LGA 1151 Slot]
CPU: Intel Core i3-6100 3M 3.7 GHz [LGA 1151 Slot]
CPU Cooler: COOLERMASTER RR-212X-20PM-R1 120mm
RAM: CORSAIR Vengeance LPX 8GB 288-Pin DDR4 SDRAM [x1 Stick]
GPU: GeForce GTX 680 2GB DDR3 PCI-E [x1 GPU]
Power Supply: EVGA 600 B1 600W 80+ Bronze
HDD: WD Blue 1TB Desktop HDD 7200 RPM 64MB Cache 3.5 Inch [x2 HDDs']
All of this is complete guesswork on my part, due to my lack of PC knowledge. Please help :(
https://linustechtips.com/topic/679969-building-an-offfice-pc/
http://pcpartpicker.com/list/Q9Qqbj
CPU: Intel Core i5-6600 3.3GHz Quad-Core Processor  ($214.99 @ SuperBiiz)
Motherboard: MSI B150M PRO-VDH Micro ATX LGA1151 Motherboard  ($61.98 @ Newegg)
Memory: G.Skill Ripjaws V Series 16GB (2 x 8GB) DDR4-2800 Memory  ($74.99 @ Newegg)
Video Card: Gigabyte Radeon RX 460 2GB WINDFORCE OC Video Card  ($104.98 @ Newegg)
Case: Fractal Design Define S ATX Mid Tower Case  ($59.99 @ Newegg)
Power Supply: EVGA 500W 80+ Bronze Certified ATX Power Supply  ($42.79 @ OutletPC)
Total: $609.21
Generated by PCPartPicker 2016-10-23 20:31 EDT-0400
https://linustechtips.com/topic/679969-building-an-offfice-pc/#findComment-8745772
Total: $609.21
B150 doesnt support overclocked memory, the gigabyte coolers are crap on the RX series, and that PSU is sketch
My Build, v2.1 --- CPU: i7-8700K @ 5.2GHz/1.288v || MoBo: Asus ROG STRIX Z390-E Gaming || RAM: 4x4GB G.SKILL Ripjaws 4 2666 14-14-14-33 || Cooler: Custom Loop || GPU: EVGA GTX 1080 Ti SC Black, on water || PSU: EVGA G2 850W || Case: Corsair 450D || SSD: 850 Evo 250GB, Intel 660p 2TB || Storage: WD Blue 2TB || G502 & Glorious PCGR Fully Custom 80% Keyboard || MX34VQ, PG278Q, PB278Q
Audio --- Headphones: Massdrop x Sennheiser HD 6XX || Amp: Schiit Audio Magni 3 || DAC: Schiit Audio Modi 3 || Mic: Blue Yeti
[Under Construction]
My Truck --- 2002 F-350 7.3 Powerstroke || 6-speed
My Car --- 2006 Mustang GT || 5-speed || BBK LTs, O/R X, MBRP Cat-back || BBK Lowering Springs, LCAs || 2007 GT500 wheels w/ 245s/285s
The Experiment --- CPU: i5-3570K @ 4.0 GHz || MoBo: Asus P8Z77-V LK || RAM: 16GB Corsair 1600 4x4 || Cooler: CM Hyper 212 Evo || GPUs: Asus GTX 750 Ti, || PSU: Corsair TX750M Gold || Case: Thermaltake Core G21 TG || SSD: 840 Pro 128GB || HDD: Seagate Barracuda 2TB
R.I.P. Asus X99-A motherboard, April 2016 - October 2018, may you rest in peace. 5820K, if I ever buy you a new board, it'll be a good one.
https://linustechtips.com/topic/679969-building-an-offfice-pc/#findComment-8745834
crap - didn't notice it was 2800 - the 500b psu is actually pretty decent for the price - which is around 40 dollars - not sure about coolers on gigabyte tho, never used them, but reviews are pretty good
https://linustechtips.com/topic/679969-building-an-offfice-pc/#findComment-8745850
Total: $598.24
https://linustechtips.com/topic/679969-building-an-offfice-pc/#findComment-8745862
CPU: Intel Xeon E3-1231 V3 3.4GHz Quad-Core Processor  ($239.99 @ SuperBiiz) video editing likes having more threads.
Motherboard: MSI H81M-P33 Micro ATX LGA1150 Motherboard  ($35.98 @ Newegg)
Memory: Corsair Vengeance 8GB (1 x 8GB) DDR3-1600 Memory  ($34.98 @ NCIX US)
Storage: SK hynix SL308 120GB 2.5" Solid State Drive  ($43.99 @ SuperBiiz)  store OS here.
Storage: Toshiba 1TB 3.5" 7200RPM Internal Hard Drive  ($45.77 @ OutletPC)
Video Card: Sapphire Radeon RX 460 2GB Video Card  ($99.99 @ Newegg)
Case: Zalman Z3 Plus White ATX Mid Tower Case  ($32.50 @ Newegg)
Power Supply: Corsair CXM 450W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($25.00 @ Newegg)
Total: $593.18
Generated by PCPartPicker 2016-10-23 20:50 EDT-0400
https://linustechtips.com/topic/679969-building-an-offfice-pc/#findComment-8745900
i5-6500 / RX 460 4GB / 16gb RAM / 120GB SSD
Motherboard: Asus H110M-A/M.2 Micro ATX LGA1151 Motherboard  ($47.98 @ Newegg)
Memory: GeIL EVO POTENZA 16GB (2 x 8GB) DDR4-2133 Memory  ($66.99 @ Newegg)
Storage: Kingston SSDNow UV400 120GB 2.5" Solid State Drive  ($40.48 @ Newegg)
Storage: Toshiba P300 1TB 3.5" 7200RPM Internal Hard Drive  ($49.99 @ Newegg)
Video Card: Gigabyte Radeon RX 460 4GB WINDFORCE OC Video Card  ($119.99 @ Newegg)
Case: Fractal Design Core 1000 USB 3.0 MicroATX Mid Tower Case  ($29.99 @ Newegg)
Total: $576.21 ($605 without the rebates)
  • Quote people's post else they won't know you replied.
Crapware | 4670k | Hyper212X | GSkill RipjawsX 16GB | Sapphire R9 280x VaporX | 840EVO 120GB | 1TB BLACK + BLUE
Logitech G102 | Corsair K70 MX Brown | HyperX Cloud
https://linustechtips.com/topic/679969-building-an-offfice-pc/#findComment-8746397
It's 2800Mhz but at $75 it's one of the cheaper 16gb right now except for the one $67($72-$5) GeiL EVO. Smartphone manufacturers are to blame for the spike in DDR4 ram prices.
The gigabyte coolers being crap is exclusively for the RX 480 G1 Gaming model, all other Gigabyte 4XX's are fine.
https://linustechtips.com/topic/679969-building-an-offfice-pc/#findComment-8746461
I really like this PC, it's the cheapest here and I like that you added an SSD. Plus I like that you got most of these parts off one website! Like I said, I don't know much about PCs' so I can't really talk specs but all I can say is, good job man! (I like the case but I'll probably swap to a more professional looking one)
This is probably the PC I will build at some point :D
https://linustechtips.com/topic/679969-building-an-offfice-pc/#findComment-8749074
Total: $593.18
I also like the PC you created, and I'm pleasantly surprised by the choice of CPU. The addition of an SSD is much appreciated, and I'm happy you kept the HDD at 1TB of storage. I don't really like the case but I could swap that for a more professional looking one anyways.
This is definitely something I would consider building :D
https://linustechtips.com/topic/679969-building-an-offfice-pc/#findComment-8749087
Total: $598.24
I am absolutely LOVING this PC. I really like the CPU you picked out, the addition of 8 more GBs of RAM is much appreciated. The case is awesome, I like the GPU, and the power supply is small and non-offensive.
If I did buy a new mouse and keyboard, would you have any suggestions? I would be looking for something that functions well in an office setting, no RGB lighting or special clicky keys. As for a mouse, I only need one thing, no wires.
Overall, I love this PC, and it's probably going to be sitting on my desk soon :D (comic sans rules all)
https://linustechtips.com/topic/679969-building-an-offfice-pc/#findComment-8749106
Total: $609.21
I like this PC, the newer CPU is good. The case is beautiful and I can't complain about any of the other parts. Overall it's nice but sadly Cereal built something I like more for cheaper.
I appreciate the PC you've compiled, this would probably be my first choice if it wasn't for the price :)
https://linustechtips.com/topic/679969-building-an-offfice-pc/#findComment-8749119
And if you'd like, you can opt for the NZXT 210 or the Fractal Design Core 2300. Both of these have the same sleek and professional look
"Better to be bad at video games than mad at video games" - BadAtVideogamesMan
https://linustechtips.com/topic/679969-building-an-offfice-pc/#findComment-8749218
Glad you like it and hope it serves you well. feel free to switch out the case, plenty more options out there
https://linustechtips.com/topic/679969-building-an-offfice-pc/#findComment-8752079
No SSD?  You crazy dude.
$625, no OS:
CPU Cooler: CRYORIG M9i 48.4 CFM CPU Cooler  ($19.99 @ Newegg)
Motherboard: ASRock H110M-HDS Micro ATX LGA1151 Motherboard  ($49.98 @ Newegg)
Memory: Kingston FURY 8GB (1 x 8GB) DDR4-2133 Memory  ($43.88 @ OutletPC)
Storage: Crucial MX300 275GB 2.5" Solid State Drive  ($69.95 @ SuperBiiz)
Video Card: XFX Radeon RX 470 4GB Triple X Video Card  ($174.98 @ Newegg)
Case: Fractal Design Core 1000 USB 3.0 MicroATX Mid Tower Case  ($24.99 @ SuperBiiz)
Total: $604.56
Generated by PCPartPicker 2016-10-25 00:51 EDT-0400
https://linustechtips.com/topic/679969-building-an-offfice-pc/#findComment-8752135
$625, no OS:
Total: $604.56
This seemed okay as I was reading down the parts list and OH GOD only 275GBs of storage. One of my "Needs" was lots of storage. (Yes I know I could add an HDD to the PC) And I'm not much of a fan of the GPU, it seems a bit beefy for what I need. Plus I don't reeeaaally want/need an SSD, that's just a plus. A regular HDD to store files in is fine.
Probably not even in the running, sorry :P
https://linustechtips.com/topic/679969-building-an-offfice-pc/#findComment-8754641
Storage you can add on for roughly $40 per TB, that RX 460 you will be stuck with.
The RX 460 and RX 470 are not even remotely close in performance.
RX 470 is close to GTX 970 performance.
RX 460 is close to GTX 950 performance.
https://linustechtips.com/topic/679969-building-an-offfice-pc/#findComment-8755488
That's exactly why I said I didn't like the PC :P
https://linustechtips.com/topic/679969-building-an-offfice-pc/#findComment-8759800
