Fix my sound?
Solved by Beeeyeee,
1 minute ago, Volbet said:What kind of sound solution are you using?
If there's any 3D, virtual surround or room correcting feature you could try turning it off.
odd. I turned ON the virtual 7.1 surround and it sounds perfect now. odd!
PopsicleHustler ·
Posted in Audio4 -
4
4
Greasy_Pudding ·
Sveeno ·
Posted in LTT Releases8 -
4
thrasher_565 ·
Posted in Hot Deals0 -
6
YoungBlade ·
Posted in CPUs, Motherboards, and Memory11
play_circle_filled
Latest From ShortCircuit:
