I want to build a PC that can do some high level detail gaming, some Adobe Photoshop and HTML 5 coding. I don't mind if the case is ATX but I would like it to be a small form factor. I would like some flexibility and for it to be future proof with upgrades. I want to have an Sli setup on preferably a Gtx 970/980.
Thanks for the help in advance.
 If any further information is needed please ask!
https://linustechtips.com/topic/679459-help-building-a-pc/
no such thing as future proof first... also what is your budget
CPU-i7 6700k O.C. 4.6Ghz-Motherboard-Asus z170-a-RAM-24gb DDR4-GPU-EVGA GTX 1080 FE-Case-Corsair 400c (white)-Storage-HDD: 2xWD Blue 1TB SSD: PNY SSDSC120GLC709B121-510 120GB-PSU-1000 watt coolermax-Display-ASUS VG248QE Black 24" 1080p 144 Hz -Cooling-Corsair H115i-Keyboard-G.Skill KM780 Cherry MX blues (Red backlight)-Mouse-Logitech G602-Sound-Logitech 5.1 z506
Need a budget headphone for under 100$? Sennheiser HD 558 Headphones
Got a Skylake CPU (k) Here is a guide to OC it!
https://linustechtips.com/topic/679459-help-building-a-pc/#findComment-8740257
SLI, especially on last gen hardware, is not worth it. For the money you will spend on two GTX 980s, you could probably get a GTX 1080 and have the same performance when SLI scales well, and way better performance when it doesn't
Whats your budget? where are you located? do you need peripherals too?
My Build, v2.1 --- CPU: i7-8700K @ 5.2GHz/1.288v || MoBo: Asus ROG STRIX Z390-E Gaming || RAM: 4x4GB G.SKILL Ripjaws 4 2666 14-14-14-33 || Cooler: Custom Loop || GPU: EVGA GTX 1080 Ti SC Black, on water || PSU: EVGA G2 850W || Case: Corsair 450D || SSD: 850 Evo 250GB, Intel 660p 2TB || Storage: WD Blue 2TB || G502 & Glorious PCGR Fully Custom 80% Keyboard || MX34VQ, PG278Q, PB278Q
Audio --- Headphones: Massdrop x Sennheiser HD 6XX || Amp: Schiit Audio Magni 3 || DAC: Schiit Audio Modi 3 || Mic: Blue Yeti
[Under Construction]
My Truck --- 2002 F-350 7.3 Powerstroke || 6-speed
My Car --- 2006 Mustang GT || 5-speed || BBK LTs, O/R X, MBRP Cat-back || BBK Lowering Springs, LCAs || 2007 GT500 wheels w/ 245s/285s
The Experiment --- CPU: i5-3570K @ 4.0 GHz || MoBo: Asus P8Z77-V LK || RAM: 16GB Corsair 1600 4x4 || Cooler: CM Hyper 212 Evo || GPUs: Asus GTX 750 Ti, || PSU: Corsair TX750M Gold || Case: Thermaltake Core G21 TG || SSD: 840 Pro 128GB || HDD: Seagate Barracuda 2TB
R.I.P. Asus X99-A motherboard, April 2016 - October 2018, may you rest in peace. 5820K, if I ever buy you a new board, it'll be a good one.
https://linustechtips.com/topic/679459-help-building-a-pc/#findComment-8740259
Any budget? Peripherals (monitor, keyb, OS, speakers)?
Athlon X2 for only 27.31$   Best part lists at different price points   Windows 1.01 running natively on an Eee PC
My rig:
Celeronator (new main rig)
CPU: Intel Celeron (duh) N2840 2.16GHz Dual Core
RAM: 4GB DDR3 1333MHz
HDD: Seagate 500GB
GPU: Intel HD Graphics 3000 Series
Frankenhertz (ex main rig)
CPU: Intel Atom N2600 1.6GHz Dual Core
RAM: 1GB DDR3-800
HDD: HGST 320GB
GPU: Intel Graphics Media Accelerator (GMA) 3600
https://linustechtips.com/topic/679459-help-building-a-pc/#findComment-8740260
2 minutes ago, Unfamiliar said:
My budget is   £ 1000 and I have got monitors from previous build with peripherals. I am from the UK.
You won't be able to have a good SLI 970 system with a budget like that. What would be your second choice?
Two 970s alone would be half the budget.
† Christian Member †
For my pertinent links to guides, reviews, and anything similar, go here, and look under the spoiler labeled such. A brief history of Unix and it's relation to OS X by Builder.
https://linustechtips.com/topic/679459-help-building-a-pc/#findComment-8740289
Sorry, I meant I would buy another in the future and just have one for now.
https://linustechtips.com/topic/679459-help-building-a-pc/#findComment-8740302
CPU: Intel Core i7-6700 3.4GHz Quad-Core Processor  (£272.28 @ Aria PC)
Motherboard: Asus H110M-A Micro ATX LGA1151 Motherboard  (£69.99 @ Amazon UK)
Memory: G.Skill Ripjaws V Series 16GB (2 x 8GB) DDR4-2400 Memory  (£69.98 @ Novatech)
Storage: Kingston SSDNow UV400 240GB 2.5" Solid State Drive  (£59.96 @ BT Shop)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  (£45.48 @ Amazon UK)
Video Card: Zotac GeForce GTX 1070 8GB AMP! Edition Video Card  (£389.99 @ Ebuyer)
Case: Thermaltake Core V21 MicroATX Mini Tower Case  (£51.99 @ Amazon UK)
Power Supply: EVGA 750W 80+ Gold Certified Semi-Modular ATX Power Supply  (£84.98 @ Novatech)
Total: £1044.65
Generated by PCPartPicker 2016-10-22 23:06 BST+0100
Like I said in my reply before, GTX 970s are not worth SLI, I would know, I tried it. GTX 980 are also last gen hardware and since pascal is so much more advanced I wouldn't even bother.
I got you an mATX motherboard with a mini case, nice small form factor
https://linustechtips.com/topic/679459-help-building-a-pc/#findComment-8740307
Total: £1044.65
Thanks dude!
https://linustechtips.com/topic/679459-help-building-a-pc/#findComment-8740315
Here's a SFF build.
CPU: Intel Xeon E3-1231 V3 3.4GHz Quad-Core Processor  (£252.75 @ BT Shop)
CPU Cooler: ARCTIC Freezer 11 LP Fluid Dynamic Bearing CPU Cooler  (£15.53 @ Amazon UK)
Motherboard: Asus H81I-PLUS Mini ITX LGA1150 Motherboard  (£54.98 @ Novatech)
Memory: Crucial Ballistix Tactical 16GB (2 x 8GB) DDR3-1600 Memory  (£67.18 @ Amazon UK)
Storage: OCZ TRION 150 240GB 2.5" Solid State Drive  (£59.99 @ Amazon UK)
Storage: Western Digital WD Blue 1TB 2.5" 5400RPM Internal Hard Drive  (£41.13 @ Amazon UK)
Video Card: Palit GeForce GTX 1070 8GB Dual Video Card  (£373.30 @ Aria PC)
Case: Fractal Design Node 202 HTPC Case  (£72.18 @ Amazon UK)
Power Supply: Silverstone 450W 80+ Bronze Certified SFX Power Supply  (£63.64 @ Amazon UK)
Total: £1000.68
Generated by PCPartPicker 2016-10-22 23:09 BST+0100
https://linustechtips.com/topic/679459-help-building-a-pc/#findComment-8740326
Thanks dude!
Welcome, feel free to switch a few parts out if you need or want (like the case. Has good reviews but cases are all personal preference lol)
https://linustechtips.com/topic/679459-help-building-a-pc/#findComment-8740330
1 minute ago, GalacticRuler said:
Here's a SFF build.
Total: £1000.68
Thanks for the help again!
https://linustechtips.com/topic/679459-help-building-a-pc/#findComment-8740336
While I agree with what you say that a 1080 > 980 SLI, I have to say, when SLI scaled well, a 980 SLI would get noticeably better results then a 1080.
Main Rig
CPU: Ryzen 2700X
Cooler: Corsair H150i PRO RGB 360mm Liquid Cooler
Motherboard: ASUS Crosshair VII Hero
RAM: 16GB (2x8) Trident Z RGB 3200MHZ
SSD: Samsung 960 EVO NVME SSD 1TB, Intel 1TB NVME
Graphics Card: Asus ROG Strix GTX 1080Ti OC
Case: Phanteks Evolv X
Power Supply: Corsair HX1000i Platinum-Rated
Radiator Fans: 3x Corsair ML120
Case Fans: 4x be quiet! Silent Wings 3
https://linustechtips.com/topic/679459-help-building-a-pc/#findComment-8740365
So when you're playing rise of the tomb raider lol. That's about it. GTAV sort of. Witcher sort of. other games like far cry are eh for SLI scaling. Still not worth it over all. If it were 1070 SLI then maybe, cause they easily beat out 980s
https://linustechtips.com/topic/679459-help-building-a-pc/#findComment-8740382
Yeah, I know. a 1080 would deinfltey be better, and a 980 sli isn't worth it. I'm just saying, if SLI scaled well, a 980 SLI would win significantly.
Main Rig
CPU: Ryzen 2700X
https://linustechtips.com/topic/679459-help-building-a-pc/#findComment-8740396
<DELETED>
******If you paste in text into your post, please click the "remove formatting" button for night theme users.******
CPU- Intel 6700k OC to 4.69 Ghz GPU- NVidia Geforce GTX 970 (MSI) RAM- 16gb DDR4 2400 SSD-2x500gb samsung 850 EVO(SATA) Raid 0 HDD- 2tb Seagate Case- H440 Red w/ custom lighting Motherboard - MSI Z170 Gaming A OS- Windows 10 Mouse- Razer Naga Epic Chroma, Final Mouse 2016 turney proKeyboard- Corsair k70 Cherry MX brown
https://linustechtips.com/topic/679459-help-building-a-pc/#findComment-8740421
