Just to make sure, you can run an Ethernet cable off your router to your computer and still have the router broadcast the wireless connection right? The Xfinity Modem/Router I have right now has a "broadcasting ability" aka a router inside of it. Just an fyi.
"May your frame rates be high and your temperatures low"
I misread titles/posts way too often--correct me if I don't.
https://linustechtips.com/topic/677587-xfinity-modem-help/
ˊ ` ` ` ` ` ` ` ` ` ` ` ` ` ` `'F'¯'''''L ` ` ` ` ` ` ` ` ` ` ` `
` ` ` ` ` ` ` ` ` ` ` ` ` ` ` `'[``…'¾`` ``` ``` ``` ```
` ` ` ` ` ` ` ` ` ` ` ` ` ` ` `'[```…ʹ[` ` ` ` ``` ``` ```
` ` ` ` ` ` ` ` ` ` ` ` ` ` ` `#````ˆ[```` ``` ``` ``` ``
` ` ` ` ` ` ` ` ` ` ` ` ` ` #…`````'F`` ` ` ` `` ``` ```
` ` ` ` ` ` ` ` ` ` ` ` ` ƒ¯```````'[__` ` ` ` ` ` ` ``` ``
` ` ` ` ` ` ` ` ` ` ` ` ƒ¯````````ʹ¯¯¯¯''''''''''''¯¯¯¯¯¯™[ `
gµµµµµµµµµµµµµµ_µ™`````````````````````````'# `
'₫₫₫₫₫₫₫₫₫₫₫₫₫F¯…`````````````````````` ` ²q[¯ ` `
ʹ₫₫₫₫₫₫₫₫₫₫₫₫¾````````````````````````````ʹ} … `
›₫₫₫₫₫₫₫₫₫₫₫₫#`````````````````````````__µr… ` `
³₫₫₫₫₫₫₫₫₫₫₫₫₫…`````````````````````````¯[ … ` `
`₫₫₫₫₫₫₫₫₫₫₫₫$``````````````````````````_F … ` `
`]₫₫₫₫₫₫₫₫₫₫₫#````````````````````````ʹ''''[… … ` `
`'₫₫₫₫₫₫₫F''''']₫#___`````````````````````` '# … ` `
…₫₫₫₫₫₫₫bµ₫₫₫₫$¯''''¹uuuuuɷuɷuɷuɷuɷuɷµ#¯ ` ` ` ` `
My native language is C++
https://linustechtips.com/topic/677587-xfinity-modem-help/#findComment-8720564
also, will the internet connection be altered in any way if i connect it to my pc via Ethernet. Like will the wireless connection become slower?
https://linustechtips.com/topic/677587-xfinity-modem-help/#findComment-8720580
so it will basically stay the same?
YES. YES IT WILL
Think of your internet connection as your water main. Your PC is the water hose. It's not running all the time, it only lets out water when you make it. If you are running your water hose (downloading), less water will be able to flow to other faucets/toilets.
https://linustechtips.com/topic/677587-xfinity-modem-help/#findComment-8720636
1 minute ago, tt2468 said:
YES. YES IT WILL
What I meant was that if I downloaded something wirelessy, it would be the same as downloading something via Ethernet cable.
https://linustechtips.com/topic/677587-xfinity-modem-help/#findComment-8720646
