So i been using Ethernet for all my life, now that i did not pay wifi i was able to ask my neighbor for there password to use, and they gave me it just one small problem...my laptop can only catch wifi but not my desktop
So i'm looking to get a Wifi Adapter (Not a TP-LINK or anything expensive but those $4-6 ones)
So here are my questions :
1.Is it better to get a wifi adapter with a big antenna or does the small one in the adapter work as good? (USB)
2.Since my neighboor is about 15m away from me and on my laptop the wifi is good, so with a cheap adapter will i get also good speeds? (It can catch up to 150mbs,100m away)
https://linustechtips.com/topic/677556-wifi-adapter-questions/
The problem with USB adapters, is the power that USB delivers to them... at best it will be 1amp... which just doesn't provide much power.
Not only that, they got hot really quickly.  I'd highly recommend a PCI based solution.
Please spend as much time writing your question, as you want me to spend responding to it.  Take some time, and explain your issue, please!
If you need to learn how to install Windows, check here:  http://linustechtips.com/main/topic/324871-guide-how-to-install-windows-the-right-way/
Event Viewer 101: https://youtu.be/GiF9N3fJbnE
https://linustechtips.com/topic/677556-wifi-adapter-questions/#findComment-8720195
Go on pcpartpicker, go to wireless adapters, sort by highest reviews, and click the first one that suits your budget
My Build, v2.1 --- CPU: i7-8700K @ 5.2GHz/1.288v || MoBo: Asus ROG STRIX Z390-E Gaming || RAM: 4x4GB G.SKILL Ripjaws 4 2666 14-14-14-33 || Cooler: Custom Loop || GPU: EVGA GTX 1080 Ti SC Black, on water || PSU: EVGA G2 850W || Case: Corsair 450D || SSD: 850 Evo 250GB, Intel 660p 2TB || Storage: WD Blue 2TB || G502 & Glorious PCGR Fully Custom 80% Keyboard || MX34VQ, PG278Q, PB278Q
Audio --- Headphones: Massdrop x Sennheiser HD 6XX || Amp: Schiit Audio Magni 3 || DAC: Schiit Audio Modi 3 || Mic: Blue Yeti
[Under Construction]
My Truck --- 2002 F-350 7.3 Powerstroke || 6-speed
My Car --- 2006 Mustang GT || 5-speed || BBK LTs, O/R X, MBRP Cat-back || BBK Lowering Springs, LCAs || 2007 GT500 wheels w/ 245s/285s
The Experiment --- CPU: i5-3570K @ 4.0 GHz || MoBo: Asus P8Z77-V LK || RAM: 16GB Corsair 1600 4x4 || Cooler: CM Hyper 212 Evo || GPUs: Asus GTX 750 Ti, || PSU: Corsair TX750M Gold || Case: Thermaltake Core G21 TG || SSD: 840 Pro 128GB || HDD: Seagate Barracuda 2TB
R.I.P. Asus X99-A motherboard, April 2016 - October 2018, may you rest in peace. 5820K, if I ever buy you a new board, it'll be a good one.
https://linustechtips.com/topic/677556-wifi-adapter-questions/#findComment-8720203
https://linustechtips.com/topic/677556-wifi-adapter-questions/#findComment-8720214
Well how can i check how much mine provides? I just want it to deliver good performance
I don't mind heat allot, as long as it works for a good 2-4 years i'm happy
I can't since i don't live in any of those countries that PPP supplies, i'm lonely
https://linustechtips.com/topic/677556-wifi-adapter-questions/#findComment-8720217
Then you should tell us that before we all post US links lol
https://linustechtips.com/topic/677556-wifi-adapter-questions/#findComment-8720229
You didn't read what I wrote then, or you don't understand how heat and power works in the realm of electronics.
If you give a antenna 10 watts of power it will get x range and performance.  If you give it 20 watts of power, it will get 2x range and performance.
Not only that, heat will degrade the life of a product.  ASUS released a article a few years ago that says every 5 degrees Celsius under the rated temperatures will double the life of the product.
SO, heat kills the longevity (and typically performance) and USB cant give the adapter enough power to do more than just function.
https://linustechtips.com/topic/677556-wifi-adapter-questions/#findComment-8720250
Ik, i just need the answers, not a recommendation really
But your help counts!
Oh lol. PCIe adapter
https://linustechtips.com/topic/677556-wifi-adapter-questions/#findComment-8720254
Ok ok, so USB is out
Now i been looking for you know used PCI-E adapters and this is what i stepped on, it costs $5 (with box) and its a Asus PCE-N15, now i don't know if this is a huge step up or not so i need help
2 minutes ago, dexxterlab97 said:
Save money and make laptop and share laptop's internet with cable?
Like connect a Ethernet cable to my laptop and then the other end to my PC? I originally though about it but i did not know if it would work or how good the performance would be...
https://linustechtips.com/topic/677556-wifi-adapter-questions/#findComment-8720289
I do that all the time. The problem is the wifi (out of range maybe) and not mobility (you can't move laptop with those wires). No extra software needed even as it is implemented with Windows
https://linustechtips.com/topic/677556-wifi-adapter-questions/#findComment-8720298
OOOOOOOH, IDK ill try it out and if it is good enough ill save some cahs
I though about it but didn't think it will work...
Mobility is not the problem as my setup is bulky as it is and i don't plan on moving it
THANKS FOR THE TIP !
https://linustechtips.com/topic/677556-wifi-adapter-questions/#findComment-8720306
Man, you spending $5 isn't going to get you very far...  That adapter is better than almost any USB adapter, but I really think you should spend $30-40 to get something that is worth while.
https://linustechtips.com/topic/677556-wifi-adapter-questions/#findComment-8720309
I really can't as i'm broke af, MAX i can spend is $10 and this is probably the best option
I'm gonna try @dexxterlab97 trick and if it works i'm be hella lot happy
https://linustechtips.com/topic/677556-wifi-adapter-questions/#findComment-8720324
Yea, your typical WiFi adapter in a notebook is somewhere in the $20-$25 range...
That coupled with the antenna is like 3 feet long.
Anyways, the pass through internet sharing isn't a bad option.  It can provide 90% of the raw performance easily, most of the time you'll be hitting in the 99% range.
https://linustechtips.com/topic/677556-wifi-adapter-questions/#findComment-8720337
Yeah the owner's router where I use is shit so I had to use this way. It can't use Ethernet but fine with WiFi
https://linustechtips.com/topic/677556-wifi-adapter-questions/#findComment-8720355
