Could a subwoofer damage a PC?
Go to solution Solved by Samsterstorm,
10 minutes ago, refinedskillz said:
I have a 2.1 sound system, the subwoofer sits under my desk, right next to my PC, is it bad for the PC? I just hear my whole case shake when it's on. Just wondering.
I bump mine pretty hard and my case doesnt shake (h440 ftw) but it makes the floor board downstairs move and I haven't had any damage yet! I mean if you have a 18inch sub at like 10hz u maybe have issues but u will be fine with any system connected to a computer ahah!
Only if you throw the subwoofer at the pc repeatedly.
seriously though, as others have said, the HDDs are the only sensitive part. either get ones equipped for vibrations, or go completely solid state, or just put a NAS in a different room
QUOTE/TAG ME WHEN REPLYING
Spend As Much Time Writing Your Question As You Want Me To Spend Responding To It.
If I'm wrong, please point it out. I'm always learning & I won't bite.
Laptop:
Lenovo Yoga 7 Air: Ryzen 7840S, 32GiB DDR5
Desktop (Old but I never replaced it):
Delidded Core i7 4770K - GTX 1070 ROG Strix - 16GB DDR3 @2000Mhz
'FrostNova' https://uk.pcpartpicker.com/user/Samsterstorm/saved/WtBWGX :
CPU: Intel 4790k | MB: Asrock Z97 Extreme6 | GPU: Gigabyte GTX 970 G1 Gaming (+200, +250) | CASE: NZXT H440 (Black & Blue) | COOLER: Full EK 240mm CPU Loop | RAM: 16GB Hyper-X Fury (4x4GB @2133mhz) | STORAGE: Seagate Barracuda 1TB & Hyperx 120gb SSD | PSU: Corsair RM650 | SCREEN: Benq G2750 | LIGHTING: Deepcool RGB LED Kit | KEYBOARD: CM Devastator | MOUSE: Logitech G502 | HEADSET: Hyperx Clouds White
