Apparently flashed corrupted bios to my 980Ti and now won't boot with it and just gives post code 62.
I know it's possible to recover the bios back by using another Nvidia GPU in the system. I got one junk system with Asus M2N-MX SE motherboard which happens to have integrated GeForce 6100 / nForce430 chipset on it.
Could it be possible to flash the stock bios back using the iGPU or do I need PCIe card?
Thanks.
https://linustechtips.com/topic/675082-flash-dead-980ti-back-using-nforce-430/
Well as long as the broken 980ti is properly detected by the flash program it's fine.
If you want my attention, quote meh! D: or just stick an @samcool55 in your post :3
Spying on everyone to fight against terrorism is like shooting a mosquito with a cannon
http://www.overclock.net/t/593427/how-to-unbrick-your-bricked-graphics-card-fix-a-failed-bios-flash
*You can also use onboard video if you motherboard has an IGP. The method for switching to it should be similar to the one outlined below.
| CPU: Core i7-8700K @ 4.89ghz - 1.21v  Motherboard: Asus ROG STRIX Z370-E GAMING  CPU Cooler: Corsair H100i V2 |
| GPU: MSI RTX 3080Ti Ventus 3X OC  RAM: 32GB T-Force Delta RGB 3066mhz |
| Displays: Acer Predator XB270HU 1440p Gsync 144hz IPS Gaming monitor | Oculus Quest 3 VR
