had a q8300 and 8gb of ddr2 i have it paired with a rx460 i've seen builds like this work before but it appears to bottle neck my system help
https://linustechtips.com/topic/673996-build-help/
whats going on with it...
My Build, v2.1 --- CPU: i7-8700K @ 5.2GHz/1.288v || MoBo: Asus ROG STRIX Z390-E Gaming || RAM: 4x4GB G.SKILL Ripjaws 4 2666 14-14-14-33 || Cooler: Custom Loop || GPU: EVGA GTX 1080 Ti SC Black, on water || PSU: EVGA G2 850W || Case: Corsair 450D || SSD: 850 Evo 250GB, Intel 660p 2TB || Storage: WD Blue 2TB || G502 & Glorious PCGR Fully Custom 80% Keyboard || MX34VQ, PG278Q, PB278Q
Audio --- Headphones: Massdrop x Sennheiser HD 6XX || Amp: Schiit Audio Magni 3 || DAC: Schiit Audio Modi 3 || Mic: Blue Yeti
[Under Construction]
My Truck --- 2002 F-350 7.3 Powerstroke || 6-speed
My Car --- 2006 Mustang GT || 5-speed || BBK LTs, O/R X, MBRP Cat-back || BBK Lowering Springs, LCAs || 2007 GT500 wheels w/ 245s/285s
The Experiment --- CPU: i5-3570K @ 4.0 GHz || MoBo: Asus P8Z77-V LK || RAM: 16GB Corsair 1600 4x4 || Cooler: CM Hyper 212 Evo || GPUs: Asus GTX 750 Ti, || PSU: Corsair TX750M Gold || Case: Thermaltake Core G21 TG || SSD: 840 Pro 128GB || HDD: Seagate Barracuda 2TB
R.I.P. Asus X99-A motherboard, April 2016 - October 2018, may you rest in peace. 5820K, if I ever buy you a new board, it'll be a good one.
https://linustechtips.com/topic/673996-build-help/#findComment-8681347
1 hour ago, Zyndo said:
upon what basis do you believe it is bottlenecking your system?
can't hold 30fps in gta on low
https://linustechtips.com/topic/673996-build-help/#findComment-8681351
What OS and architecture?
Cor Caeruleus Reborn v6
CPU: Intel - Core i7-8700K
CPU Cooler: be quiet! - PURE ROCK
Thermal Compound: Arctic Silver - 5 High-Density Polysynthetic Silver 3.5g Thermal Paste
Motherboard: ASRock Z370 Extreme4
Memory: G.Skill TridentZ RGB 2x8GB 3200/14
Storage: Samsung - 850 EVO-Series 500GB 2.5" Solid State Drive
Storage: Samsung - 960 EVO 500GB M.2-2280 Solid State Drive
Storage: Western Digital - Blue 2TB 3.5" 5400RPM Internal Hard Drive
Storage: Western Digital - BLACK SERIES 3TB 3.5" 7200RPM Internal Hard Drive
Video Card: EVGA - 970 SSC ACX (1080 is in RMA)
Case: Fractal Design - Define R5 w/Window (Black) ATX Mid Tower Case
Power Supply: EVGA - SuperNOVA P2 750W with CableMod blue/black Pro Series
Optical Drive: LG - WH16NS40 Blu-Ray/DVD/CD Writer
Operating System: Microsoft - Windows 10 Pro OEM 64-bit and Linux Mint Serena
Keyboard: Logitech - G910 Orion Spectrum RGB Wired Gaming Keyboard
Mouse: Logitech - G502 Wired Optical Mouse
Headphones: Logitech - G430 7.1 Channel  Headset
Speakers: Logitech - Z506 155W 5.1ch Speakers
https://linustechtips.com/topic/673996-build-help/#findComment-8681356
alot of fps drops textures are poping in
https://linustechtips.com/topic/673996-build-help/#findComment-8681359
windows 10
https://linustechtips.com/topic/673996-build-help/#findComment-8681360
Tough to say for sure without any usage charts or anything like that, but it sounds like CPU bottleneck IMO. a 460 should be able to handle low graphics GTA quite well.
But you should let us know your CPU usage, GPU usage, RAM and VRAM usage.
https://linustechtips.com/topic/673996-build-help/#findComment-8681364
Just now, masterkickass7 said:
windows 10
32 or 64-bit? This is equally as important as version.
https://linustechtips.com/topic/673996-build-help/#findComment-8681365
64
https://linustechtips.com/topic/673996-build-help/#findComment-8681367
possibly the q8300 even though i've seen q6600s work with 950s
https://linustechtips.com/topic/673996-build-help/#findComment-8681369
Yes. but like i said earlier, you need to tell us what your hardware monitoring software is telling you when running the game. we need numbers in order to help you. Just naming off system specs leaves us guessing.
What is your GPU usage, CPU usage, VRAM and RAM usage?
https://linustechtips.com/topic/673996-build-help/#findComment-8681372
That's not enough. Get a monitoring software and make sure you're actually getting bottlenecked.
https://www.hwinfo.com/ or https://gaming.msi.com/features/afterburner (HWiNFO is better)
http://www.guru3d.com/files-details/rtss-rivatuner-statistics-server-download.html
Let us know if you need help setting up the monitoring tools.
Quote
The problem is that this is an nVidia product and scoring any nVidia product a "zero" is also highly predictive of the number of nVidia products the reviewer will receive for review in the future.
On 2015-01-28 at 5:24 PM, Victorious Secret said:
Only yours, you don't shitpost on the same level that we can, mainly because this thread is finally dead and should be locked.
On 2016-06-07 at 11:25 PM, patrickjp93 said:
I wasn't wrong. It's extremely rare that I am. I provided sources as well. Different devs can disagree. Further, we now have confirmed discrepancy from Twitter about he use of the pre-release 1080 driver in AMD's demo despite the release 1080 driver having been out a week prior.
On 2016-09-10 at 4:32 PM, Hikaru12 said:
You apparently haven't seen his responses to questions on YouTube. He is very condescending and aggressive in his comments with which there is little justification. He acts totally different in his videos. I don't necessarily care for this content style and there is nothing really unique about him or his channel. His endless dick jokes and toilet humor are annoying as well.
https://linustechtips.com/topic/673996-build-help/#findComment-8681406
Yes. but like I've said twice now, you need to tell us what your hardware monitoring software is telling you when running the game. we need numbers in order to help you. Just naming off system specs leaves us guessing.
% hdd usage all over place from %3 %6 %10 then spikes in to 60s and sometimes 90s
cpu fluctuates between %77-%93
about 4gb of the ddr2 is used
gpu1 at %100 gpu2 at between %22-%50s gpu at about 46 degrees
https://linustechtips.com/topic/673996-build-help/#findComment-8681407
That's not good... Since these are red cards I'll have to leave it for someone who'd know more about Crossfire.
https://linustechtips.com/topic/673996-build-help/#findComment-8681417
https://linustechtips.com/topic/673996-build-help/#findComment-8681418
i'm not in cross fire..............
https://linustechtips.com/topic/673996-build-help/#findComment-8681422
Didn't you say you're using RX 460?
https://linustechtips.com/topic/673996-build-help/#findComment-8681426
i have 1 rx460
https://linustechtips.com/topic/673996-build-help/#findComment-8681428
That is really spare data.
What you need is a graph of your individual CPU Core usage, RAM usage, GPU usage and VRAM usage. Then we can figure out what is maxed out and what needs changing.
You said your GPU sits about 46 degrees, which is good. Make sure none of your system components is overheating.
Quote
https://linustechtips.com/topic/673996-build-help/#findComment-8681436
Cpu in the low 50s
https://linustechtips.com/topic/673996-build-help/#findComment-8681450
Cpu in the low 50s
Can you download Precision and run the HW monitor in the background while playing? Once you've played for 10 or so minutes, take a screenshot and post it.
https://linustechtips.com/topic/673996-build-help/#findComment-8681456
The pc is funny with hw monitor can only get it to run once then it won't run again and I have to reinstall
https://linustechtips.com/topic/673996-build-help/#findComment-8681480
It might be necessary to try reinstalling the OS or using another motherboard.
https://linustechtips.com/topic/673996-build-help/#findComment-8681488
It is an old oem mobo and I just wasted $100 on a rx460
https://linustechtips.com/topic/673996-build-help/#findComment-8681507
