So going for an all black build but need to find some good white LEDs to go in a windowed Fractal Design R4 :) thanks guys
AMD FX-8350 II ASUS R9-20x DCU2 TOP II Fractal Design R4 II Samsung 840 Evo 250gb SSD II Gigabyte 990FXA UD-3 II 8GB Corsair XMS II Cooler Master Seidon 120mm II ACER H236HL Monitor II Corsair K70 II Razer Deathadder II Kinect II
Go check out my Build Log for my "Home Made Gaming POD"
http://linustechtips.com/main/topic/83872-home-made-gaming-pod-build-log/
https://linustechtips.com/topic/67380-best-lighting-for-case/
Phobya high density LED strips.
Folding@Home | BOINC
CPU: AMD Ryzen 9 3900X + Celsius S36 GPU: ASUS TUF RTX3080
MB: ASRock x470 Taichi RAM: Corsair Vengeance RGB DDR4-2666 32GB
CASE: Fractal Design Define 7 Panda STORAGE: WD Black SN770 2TB + WD Red Pro 6TB
https://linustechtips.com/topic/67380-best-lighting-for-case/#findComment-921936
NZXT HUE gives you all colors for a decent price, but if you definitely want white get bitfenix alchemy strips.
They seems to be very long at a medium price point so I would probably need like 3 strips so will cost me 45 pounds whilst the hue will be 30 pounds so would it be better to go for the hue ?
https://linustechtips.com/topic/67380-best-lighting-for-case/#findComment-921957
If the NZXT HUE is long enough get it. (2 metres)
https://linustechtips.com/topic/67380-best-lighting-for-case/#findComment-922001
Does the hue give as good an effect as the alchemy
https://linustechtips.com/topic/67380-best-lighting-for-case/#findComment-922018
http://i.imgur.com/aPkzJ8f.jpgI'm using a pair of Logisys sunlight sticks.
Had a look and can't find them in the uk
https://linustechtips.com/topic/67380-best-lighting-for-case/#findComment-922034
i actually don`t know but l have seen quite alot of pictures where it looks really good. (can`t get a good answer because im having dinner, but i can help you in 10-15 min)
https://linustechtips.com/topic/67380-best-lighting-for-case/#findComment-922036
Ahha ok thanks enjoy your meal
https://linustechtips.com/topic/67380-best-lighting-for-case/#findComment-922052
any more questions?
As I haven't got huge money left after buying all my components what are good cheap LEDs ?
https://linustechtips.com/topic/67380-best-lighting-for-case/#findComment-922199
NZXT sells single colored LED strips $10 for 1M length and $15 for 2M length. then there is the NZXT HUE which is good if you want to be able to change the color at will but cost $30. Then the bitfenix alchemy strips witch are about $30 for 60cm. all options look great just google image search to see builds using them if you want to compare.
nice try kids now get back in the van...........
https://linustechtips.com/topic/67380-best-lighting-for-case/#findComment-932123
