More fans on a heatsink?
EuphoricLlama
I will be changing cases from a NZXT Phantom 240 to a NZXT s340 Razer Edition which came with 2 more fans so I have an excess of fans right now so I want to know if it's a good idea to put a second fan on my heatsink. My heatsink is an Arctic Freezer i30 and it does a decent job but my cpu gets up to ~75 C which isn't awful but would it make a massive difference to attach a second fan to the front to push air through (by using a splitter to attach it to one cpu fan header)?
It can make a difference and since you've said you'll already have all the fans, why not give it a try eh? :P
Looking at my signature are we now? Well too bad there's nothing here...
What? As I said, there seriously is nothing here :)
do it, it will be atleast slightly better
Builds:
Cant make it any worse, its at least worth a try.
Please quote our replys so we get a notification and can reply easily. Never cheap out on a PSU, or I will come to watch the fireworks.
PSU Tier List
My specs
PC:
CPU: Intel Core i5-6600K @4.8GHz
CPU Cooler: Noctua NH-U14S
Motherboard:  ASUS Maximus VIII Hero
GPU: Zotac AMP Extreme 1070 @ 2114Mhz
Memory: Corsair Vengeance LPX 16GB (2 x 8GB) DDR4-2400
Storage: Samsung 850 EVO-Series 500GB
Storage: Western Digital Caviar Blue 1TB
Case: Cooler Master MasterCase Pro 5
Power Supply: EVGA 750W G2
Peripherals
Keyboard: Corsair K70 LUX Browns
Mouse: Logitech G502
Headphones: Kingston HyperX Cloud Revolver
Monitor: U2713M @ 75Hz
He can, but that would be indeed crazy if he let them blow both towards eachother :)
The object of life is not to be on the side of the majority, but to escape finding oneself in the ranks of the insane.
Basic PC parts guide
PSU Tier list
Second fan isn't going to make temps much lower. I don't how big difference is with smaller (120mm and under) heatsinks. With 140mm cooler difference was about 5C. 2nd fan helps to keep temps at same level while fans run at lower speed.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
