1. I always get a hangup and when it hangs up, my screen looks like this:
2. There are times when  I restart my pc, it took 30-60 seconds in displaying the screen Gigabyte screen (the one where it displays keys to press if i want to boot)
3. Every time I restart my pc, I can't browse the web although I can download (like for using utorrent). What I'm doing is unplug and plug my LAN cable.
4. itunes is not recognizing my
I just build this pc 2-3 weeks ago.My drivers are also updated. Here are my specs by the way:
I hope you can help me solve the following problems. Thanks
https://linustechtips.com/topic/67314-problems-with-my-new-build/
that...... is some ugly screen!
 [spoiler=CORMAC]CPU:Intel celeron 1.6ghz RAM:Kingston 400mhz 1.99gb MOBO:MSI G31TM-P21 GPU:Will add one later on! CASE:local ROUTER D-Link 2750U, D-LINK 2730U MOUSE:HP,DELL,ViP KEYBOARD: v7 SPEAKERS:Creative 245  MONITOR:AOC E970Sw HEADSET: Sony MDRx05s UPS:conex ups avr 500va PSU:idk OD:Samsung super writemaster STORAGE:80 gb seagate+ Seagate 1TB OS:Windows xp sp3 themed to Windows 7 + Linux |Rest all pc in my house will be updated from time-time
COMING SOON
https://linustechtips.com/topic/67314-problems-with-my-new-build/#findComment-921049
is it possible for you to try with a discrete GPU? Or another CPU?
My PC CPU: 2600K@4.5GHz 1.3v Cooler: Noctua NH-U12P SE2 MB: ASUS Maximus IV RAM: Kingston 1600MHz 8GB & Corsair 1600MHz 16GB GPU: 780Ti Storage: Samsung 850 Evo 500GB SSD, Samsung 830 256GB SSD, Kingston 128GB SSD, WD Black 1TB,WD Green 1TB. PSU: Corsair AX850 Case: CM HAF X. Optical drive: LG Bluray burner  MacBook Pro, Hackintosh
https://linustechtips.com/topic/67314-problems-with-my-new-build/#findComment-921097
Well the screen suggests gpu problem, long loading screen something else... Have you tried with one ram stick? And check all cables.
I'm only using the HD4600. I don't have a gpu yet. I'm just planning to buy soon once 290x is out.
https://linustechtips.com/topic/67314-problems-with-my-new-build/#findComment-921124
Yeah, this is definetly a GPU problem, but if you're using the HD4600, than it's your CPU that has problems... Well that's how I see it...
VIDEO GAMES                                  Max Power Build Log
https://linustechtips.com/topic/67314-problems-with-my-new-build/#findComment-921140
All drivers are updated. About the BIOS, I guess no? I don't know how to update a BIOS. sorry
http://www.gigabyte.com/products/product-page.aspx?pid=4482&dl=1#bios download and execute this one. It defaults any changes you have done in BIOS like boot order but nothing else is changed. Should be ok, I updated same version on my BIOS (UD3H) after 2 days of figuring out whats wrong with fan controls and Gigabyte software not working at all.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/67314-problems-with-my-new-build/#findComment-921415
Thanks for that. I hope this one solves the problems.
EDIT:
I go this error when I run the autoexec.bat
The program or feature "\??\C:\Users\Elvin Gentiles\Desktop\Efiflash.exe" cannot start or run due to incompatibity with 64-bit versions of Windows. Please contact the software vendor to ask if a 64-bit Windows compatible version is available.
https://linustechtips.com/topic/67314-problems-with-my-new-build/#findComment-921775
You can use Gigabytes own software to update bios if that file doesn't work. You need to have Gigabytes APP Center installed and then use @BIOS. It can look bit scary but works ok.
https://linustechtips.com/topic/67314-problems-with-my-new-build/#findComment-922337
thanks for that. I already used it and I'll observe this pc if it will happen again. I'll post once it happened again. Thanks :)
https://linustechtips.com/topic/67314-problems-with-my-new-build/#findComment-925748
