I have Thermaltake X5 Green RiING edition case. Is there any shroud or anything that I could strap to the bottom of the case to hide the cables? Looks terrible. I tried spiral cable wraps but I don't have enough and I'm not sure if it's worth getting more.
Main PC:
CPU: Intel Core i9 14900KS SP 109 (125P-79E) (6.1Ghz P-Cores 4.8Ghz E-cores) MC SP 88
CPU Voltage: LLC6 1.43V
Cooled by: Supercool Direct Die 14th gen full nickel
Motherboard: Z790 ASUS Maximus Apex Encore
RAM: GSkill TridentZ 2x24GB DDR5 8800Mhz Watercooled
GPU: RTX 5090 Palit OC with Alphacool Core Waterblock
Case: TT P3
Storage: 4x 2TB Sarbent Rocket Plus Gen 4.0 NVMe, 1x External 2TB Seagate Barracuda (Backup)
PSU: Corsair AX1600i with custom black and red cables with 2x Corsair 5V+ Load Balancer
Display: Samsung Oddysey G9 57" 240Hz Ver. 7680x2160 and
2x ASUS XG17AHP 240hz 17"
Fan Controllers:  6x AquaComputer Octo
Cooling: Three Custom Loops:
1st Loop: 5x 480mm XE CoolStream radiators with 1x Revo D5 RGB pump and 1x Rajintek Antila D5 Evo RGB pump for GPU only cooling with 2x Koolance QDC3, red coolant
2nd Loop: 5x 480mm XE CoolStream radiators with 1x Revo D5 RGB pump and 1x Rajintek Antila D5 Evo RGB pump for CPU only cooling with 2x Koolance QDC3, purple coolant
3x 360mm PE EKWB CoolStream
3rd Loop: 1x 240mm PXE CoolStream radiator with 1x EKWB Revo D5 pump (RAM ONLY) - Back of the case
2nd Main PC is same as above, except Display is Philips Evnia 49" 5120x1440 240hz QD-OLED, 48GB 8400Mhz RAM, 8TB NVMe
1st LaptopMSI Titan HX18 Dragon EditionRTX 5090 175W, Core Ultra 285HX,  128GB of RAM @5600Mhz / 96GB @6400Mhz
8TB of NVMe - GPU and CPU with LM on, Llano V12
2nd Laptop: MSI Raider 18HX, RTX 5090 175W, 9955HX3D, 128GB DDR5 @5600Mhz, 8TB NVMe, CPU and GPU LM on, Llano V12
3rd Laptop: MSI Titan 18HX, RTX 4090 175W, 14900HX, 224GB DDR5 @3600Mhz, 8TB NVMe
HTPC:
CPU: Intel Core i9 14900K (SP99 P111 E76), CPU Voltage: 1.33V, Cooled by: Supercool Direct Die 12th gen full nickel, Motherboard: Z790 Apex
RAM: GSkill TridentZ 2x24GB DDR5 8000Mhz CL40, GPU: RTX 5090 Palit Gamerock with Alphacool Waterblock,  Case: Corsair 6500D, Storage: 3x2TB PM9A1 Samsung NVMe Gen 4
WiFi: Wifi 6E Built in, PSU: AX1600i Corsair Titanium, Display: Philips Evnia 49" 240Hz OLED, Fan Controllers:  1x DH-10 DeepCool and Deepcool RGB hub, Loop: 2x 360mm XE CoolStream radiator, 1x 360mm PE Coolstream Radiator, 1x 240mm XE CoolStream Radiator, Revo D5 EKWB Pump, 19x Corsair 120ML RED LED fans 2000RPM
https://linustechtips.com/topic/672461-cable-management-help/
For a shroud you could purchase a piece of acrylic and cut it to size to act as a shroud, looks to be a lot of mounting points and options to easily facilitate that in the case.
-Moved to Modding Section-
https://linustechtips.com/topic/672461-cable-management-help/#findComment-8665983
18 minutes ago, Himommies said:
Whats the point of the cable wraps there hiding your cables and they make it look funny
I didn't ask for an opinion on how it looks and why it looks like that. I asked if there is any contraption which hides them.
Main PC:
Case: TT P3
HTPC:
https://linustechtips.com/topic/672461-cable-management-help/#findComment-8666065
I was hoping I could purchase some metal cover that maybe already exist? I'm not too sure. I was thinking of something that covers the PSU like in Phanteks Enthoo Pro M. I was also thinking of zip-tying the entire cable bulk.
Main PC:
Case: TT P3
HTPC:
https://linustechtips.com/topic/672461-cable-management-help/#findComment-8666072
If it didn't come with one from the manufacture it's very unlikely there will be a pre-done unit for that unless it was custom fabricated. Personally I would leave the cables as is without the spiral wrap as they are already sleeved.
https://linustechtips.com/topic/672461-cable-management-help/#findComment-8666086
Well, I'm really not satisfied wit how they look. I will try to find something I guess.
Main PC:
Case: TT P3
HTPC:
https://linustechtips.com/topic/672461-cable-management-help/#findComment-8666136
You can get cable combs if that is the case to keep them in place and hold their shape.
https://linustechtips.com/topic/672461-cable-management-help/#findComment-8666147
I have loads, they don't work.
Main PC:
Case: TT P3
HTPC:
https://linustechtips.com/topic/672461-cable-management-help/#findComment-8666153
Not exactly sure what your going for then but they do work to keep the shape of the individual wires.
They work for main 24 pin, nothing else. I just want to hide the cables, make them look like they are one. Make it look neat?
Main PC:
Case: TT P3
HTPC:
https://linustechtips.com/topic/672461-cable-management-help/#findComment-8666170
Oh they aren't designed for that but yeah if you wanted the cables to be in a bundle them together then that would be a different style.
https://linustechtips.com/topic/672461-cable-management-help/#findComment-8666172
I bought 5m of Velcro strap. It should do the job.
Main PC:
Case: TT P3
HTPC:
https://linustechtips.com/topic/672461-cable-management-help/#findComment-8666388
in your case the wires arent so bad but as a horizontal cube owner i feel ya, i had to make a lower bay cover for my x-qber out of 22g steel and used split loom to cover the wires, you could also straight up replace the window with a solid color acrylic
https://linustechtips.com/topic/672461-cable-management-help/#findComment-8670886
I would also say, go with plastic cover. It's cheap and easy to work with tools that probabl everyone has around unlike metal with which you need metal working tools. Even with thicker plastic you can easily cut it (using saw) and file the sides smooth (preferably use sandpaper to ease the work to get smooth and even outcome), you can even get few different grit  sandpaper and polish the edges to get as close as possible metallic look. And for color there's a lot of options today, you can even get green plastic near the color of your case or just go to some hardware store with a lot of paints and ask paints (preferably spraypaints) that can be used with the plastic you get, just take care that you remember excatly what plastic you are using because there's a lot of paints that melt some plastics but can be used with others. IF you worry about the color get PC/ABS plastic sheet to work with, because then you can use most of the car paints on it (PC/ABS plastic is commonly used in car bumpers).
https://linustechtips.com/topic/672461-cable-management-help/#findComment-8671559
