Does it do anything when it blinks?
http://pcpartpicker.com/list/Mf3Zcc My build
R.I.P Donny- Got banned. We will always remember your spamming of "Cancerbooks"
iPhones are like 1 ply toliet paper with a logo slapped on them and years old hardware in them- A Wise Man
https://linustechtips.com/topic/672340-case-issue/#findComment-8664717
I would cut the LED off, but that might not be a good idea. See if you can get a replacement LED from Corsair or from a local store, and see if that helps.
https://linustechtips.com/topic/672340-case-issue/#findComment-8664732
