I'm planning on throwing in another 660ti because I can get one for $200 but the problem is that my Matx mobo won't have any spacing between the cards. Will this have any perceivable cooling issues? If so are there any cooling options like the support brace in the Haf x?
My System Specs: (Short list) i7 4770k, GTX 780, many SSD's, a 2 TB HDD(deceased :( ), Corsair 650D. Full list: http://pcpartpicker.com/user/kchriz6097/saved/8dh7YJ
Upgrade Plan: Acquire some Black Noctuas then add 16 or 32GB of 2133MHz memory
https://linustechtips.com/topic/67218-sli-or-crossfire-cooling/
There will be issues, there is a small space between them so a large amount of airflow directed at the cards will lower the temps but there wont be much you can do aside from that, throwing a fan on a side panel mount will help if your case has one.
-The Bellerophon- Obsidian 550D-i5-3570k@4.5Ghz -Asus Sabertooth Z77-16GB Corsair Dominator Platinum 1866Mhz-x2 EVGA GTX 760 Dual FTW 4GB-Creative Sound Blaster XF-i Titanium-OCZ Vertex Plus 120GB-Seagate Barracuda 2TB- https://linustechtips.com/main/topic/60154-the-not-really-a-build-log-build-log/ Twofold http://linustechtips.com/main/topic/121043-twofold-a-dual-itx-system/ How great is EVGA? http://linustechtips.com/main/topic/110662-evga-how-great-are-they/#entry1478299
https://linustechtips.com/topic/67218-sli-or-crossfire-cooling/#findComment-919576
Next time keep this to one post. https://linustechtips.com/main/topic/67214-pci-e-20-16x-at-4x/
To answer your question. I need to know if your current card is a blower fan version or a more open design. Does it exhaust out the back or into the case?
CPU: 5820k 4.5Ghz 1.28v, RAM: 16GB Crucial 2400mhz, Motherboard: Evga X99 Micro, Graphics Card: GTX 780, Water Cooling: EK Acetal CPU/GPU blocks,
240mm Magicool slim rad, 280mm Alphacool rad, D5 Vario pump, 1/4 ID 3/4 OD tubing, Noctua Redux 140/120mm fans. PSU: Evga 750w G2 SSD: Samsung 850 Pro 256GB & Seagate SSHD 2TB Audio: Sennheiser HD558s, JBL! speakers, Fiio E10k DAC/Amp Monitor: Xstar DP2710LED @ 96hz (Korean Monitor) Case: Fractal Node 804
https://linustechtips.com/topic/67218-sli-or-crossfire-cooling/#findComment-919581
660ti are not blower style. It's always open and exhausts air into case
There are 10 types of people in this world, those who understand binary, and those who don't.
https://linustechtips.com/topic/67218-sli-or-crossfire-cooling/#findComment-919603
Sorry, I thought it would be more appropriate to put it in the right category. But to answer your question I have an MSI power edition so it's an open design.
https://linustechtips.com/topic/67218-sli-or-crossfire-cooling/#findComment-919605
From EVGA they are. EVGA have both blower and open.
                    Fractal Design Arc Midi R2 | Intel Core i7 4790k | Gigabyte GA-Z97X-Gaming GT                              Notebook: Dell XPS 13
                 16GB Kingston HyperX Fury | 2x Asus GeForce GTX 680 OC SLI | Corsair H60 2013
           Seasonic Platinum 1050W | 2x Samsung 840 EVO 250GB RAID 0 | WD 1TB & 2TB Green                                 dat 1080p-ness
https://linustechtips.com/topic/67218-sli-or-crossfire-cooling/#findComment-919616
http://www.amazon.com/EVGA-GeForce-2048MB-Graphics-02G-P4-3667-KR/dp/B008WVWRLE/ref=sr_1_23?ie=UTF8&qid=1382229696&sr=8-23&keywords=660ti
Okay.
Your cards will run hotter and you will definitely want good airflow in your case but it's do-able.
(edit) Just be sure that there is room for the top card to "breathe". So you might need to use a rubber spacer or something.
Edited by Ashley
https://linustechtips.com/topic/67218-sli-or-crossfire-cooling/#findComment-919627
Double check the manual for your Mobo, Most will space the cards for you. Any motherboard I have had has always made you SLI/Crossfire in SLI slot 1+3. Only if you triple Crossfire/SLI will you use slot 1+2+3.
I have ran 480gtx's in slots 1+3 and I didint notice any real heat difference under full load (1-3c max) and believe me the 480's ran HOT!
(both reference blower styles)
Quack 🦆
https://linustechtips.com/topic/67218-sli-or-crossfire-cooling/#findComment-919631
[Okay.
Would taping a 90mm fan to the side be necessary? I'm working in a prodigy m so the only air flow will be from the top 120mm intakes.
Edit: trying to use mobile :P
https://linustechtips.com/topic/67218-sli-or-crossfire-cooling/#findComment-919639
[Okay.
If you are set on getting another 660ti and using SLI instead of getting a single card go for it and see what temps you get while gaming. Thankfully the 600 series doesn't run too hot so I think it'll be fine.
https://linustechtips.com/topic/67218-sli-or-crossfire-cooling/#findComment-919671
After reviewing the LTT archives for 660 ti videos I found the galaxy 660 ti (currently $165) has an extremely open and efficient cooler design. Because of the open sides it should be able to still bring in an adequate amount of air without much help.
https://linustechtips.com/topic/67218-sli-or-crossfire-cooling/#findComment-919716
You could have two cards that output heat up against your side panel and without it escaping there, the heat will rise and be integrated with the intakes of other fans.
If you have a side panel fan mount already, single or double, you can point it so the airflow goes out of the case, sucking air in would not help SLI/Xfire when you have two airflows conflicting.
If you don't have any side panel mounts you can create them.
Many video tutorials are online.
Here is a forum guide, to put a big 25cm fan in the spot where both cards would be expelling heat, you could also point a fan towards the cards from a HDD cage area for maybe a small benefit to GPU intake.
http://themodzoo.com/forum/index.php?/topic/403-diy-guide-installing-250mm-cooling-fan/
This guide is a reference, you can use different parts, mounts, screws and grills if you want to or at all...
Another side panel single 120mm fan install guide.
http://themodzoo.com/forum/index.php?/topic/406-diy-guide-installing-gpu-cooling-fan-in-panel/
Maximums - Asus Z97-K /w i5 4690 Bclk @106.9Mhz * x39 = 4.17Ghz, 8GB of 2600Mhz DDR3,.. Gigabyte GTX970 G1-Gaming @ 1550Mhz
https://linustechtips.com/topic/67218-sli-or-crossfire-cooling/#findComment-919923
i dont get why they dont do this
that'd be cool.
and as for OP, I'd get a new card instead and let go the 660 - but this is coz I tried having my 680s right next to each other and with the heat it hits 100'C
so yea, I'd avoid it if it's all possible.
have a good directed fans to try and push the heat as much as you can.
Check out the build: Used to be Obot, now Lilith
Shameless: Me
https://linustechtips.com/topic/67218-sli-or-crossfire-cooling/#findComment-919952
You were saying something about 660ti never being blower?
geforce-gtx-660ti-3qtr.png?itok=nKhiJglx
It's rare that people buy the nVidia one, but there definitely is blower solutions.
Also, if there is virtually no spacing between the cards, consider a water loop.
https://linustechtips.com/topic/67218-sli-or-crossfire-cooling/#findComment-919975
Yeah, I should have said there are few blower styles. But most people buy the Twin Frozr, gigabyte or something like that. Also, the guy actually does have the MSI TF
https://linustechtips.com/topic/67218-sli-or-crossfire-cooling/#findComment-921535
