2 minutes ago, daviden said:
Laptop won't connect to wifi no matter what I do. After waking up after sleep it turns off and sometimes restarting doesn't even do anything.
BTW I hope this is the right forum:S
So is the wifi the problem or the laptop... do you mean the wifi turns off after waking from sleep.. or the laptop itself?
If you mean the wifi, are you sure it's turned off the wifi adaptor? and not just you can't access the network?
Please quote my post, or put @paddy-stone if you want me to respond to you.
  • PCs:-
  • Main PC build  https://uk.pcpartpicker.com/list/2K6Q7X
  • ASUS x53e  - i7 2670QM / Sony BD writer x8 / Win 10, Elemetary OS, Ubuntu/ Samsung 830 SSD
  • Lenovo G50 - 8Gb RAM - Samsung 860 Evo 250GB SSD - DVD writer
  • Displays:-
  • Philips 55 OLED 754 model
  • Panasonic 55" 4k TV
  • LG 29" Ultrawide
  • Philips 24" 1080p monitor as backup
  • Storage/NAS/Servers:-
  • ESXI/test build  https://uk.pcpartpicker.com/list/4wyR9G
  • Main Server https://uk.pcpartpicker.com/list/3Qftyk
  • Backup server - HP Proliant Gen 8 4 bay NAS running FreeNAS ZFS striped 3x3TiB WD reds
  • HP ProLiant G6 Server SE316M1 Twin Hex Core Intel Xeon E5645 2.40GHz 48GB RAM
  • Gaming/Tablets etc:-
  • Xbox One S 500GB + 2TB HDD
  • PS4
  • Nvidia Shield TV
  • Xiaomi/Pocafone F2 pro 8GB/256GB
  • Xiaomi Redmi Note 4
  • Unused Hardware currently :-
  • 4670K MSI mobo 16GB ram
  • i7 6700K  b250 mobo
  • Zotac GTX 1060 6GB Amp! edition
  • Zotac GTX 1050 mini
https://linustechtips.com/topic/672061-big-wifi-problem/#findComment-8662009
sorry for the vagueness, I meant the wifi will turn off after waking, and in the settinsg it won't allow me to turn it on
https://linustechtips.com/topic/672061-big-wifi-problem/#findComment-8662033
Probably a energy savings setting. You can check energy settings in windows, or maybe your laptop has software on it that also makes certain energy saving rules.
The object of life is not to be on the side of the majority, but to escape finding oneself in the ranks of the insane.
Basic PC parts guide
PSU Tier list
https://linustechtips.com/topic/672061-big-wifi-problem/#findComment-8662039
OK, if you go into the control panel [right click start icon, choose "control panel"] - go into "network and internet" then "network and sharing centre" ... take a picture or a snip using snipping tool of what it says there, like this
then click "change adaptor settings on the left hand manu items"
 and again take a pic/snip.
  • PCs:-
  • Displays:-
  • LG 29" Ultrawide
  • PS4
  • Nvidia Shield TV
https://linustechtips.com/topic/672061-big-wifi-problem/#findComment-8662061
might take a sec considering it cant connect to the internet so ill have to transfer via usb to this computer, hold on...
Edited by daviden
https://linustechtips.com/topic/672061-big-wifi-problem/#findComment-8662096
OK, sorry for the very late reply here, but I was very tired and had to sleep.
Ok, in the second menu, right click on the wifi adaptor and select "connect"
Can you tell me what it says?  I couldn't really see those pics you posted before, but could just make out that there were no networks connected... and that ethernet is disabled and wifi not connected.
  • PCs:-
  • Displays:-
  • LG 29" Ultrawide
  • PS4
  • Nvidia Shield TV
https://linustechtips.com/topic/672061-big-wifi-problem/#findComment-8664188
Well after a restart it worked again, but the next time it happens I'll tell you what I see
https://linustechtips.com/topic/672061-big-wifi-problem/#findComment-8669811
