Hello,
I have recently built a computer with an i7 6700k and a MSI Z170a SLI Plus motherboard. I was able to overclock my CPU to 4.4ghz and gave it 1.25Volts. Now the computer is dead and the only hint I could find is the EZ Debug led on the motherboard lighting up for CPU but everything else turns on (fans spin, lights turn on, etc.) What could be the problem with my cpu?
https://linustechtips.com/topic/671207-6700k-issue/
@gtx1060=valueI tried can't access the bios because I can't even get a post
@wrathoftheturkey I tried earlier and just now and I still have the same issue
@Crossbred I took out my reset the CMOS, then put the CPU back in place
@EndriviaI was able to run Firestrike and Aida 64 while the CPU was running at 4.4ghz
https://linustechtips.com/topic/671207-6700k-issue/#findComment-8652650
