Can anyone help me choose?
stevenchoi56
I wanted to upgrade my headphones for a long time and I found this local store are selling some demo headphones and I am just wondering what your opinions on these are? I will be using a schiit valhalla and bitfrost for them.
The headphones are:
MrSpeakers Ether
Audeze LCD-2
Audeze EL-8
Hifiman Edition X
or
Focal Elear( not open box)
How much do they all cost?
-----> Official Unofficial Favorite Keyswitch Type Survey <-----
 OWNER OF THE FASTEST INTEL iGPU ON LTT UNIGINE SUPERPOSITION [lol]
GAMING RIG "SNOWBLIND"
CPU i5-13600k | COOLING Corsair H150i Elite Capellix 360mm (White) | MOTHERBOARD Gigabyte Z690 Aero G DDR4 | GPU Gigabyte RTX 3070 Vision OC (White) | RAM  16GB Corsair Vengeance Pro RGB (White)SSD Samsung 980 Pro 1TB | PSU ASUS STRIX 850W (White)CASE  Phanteks G360a (White) | HEADPHONES  Beyerdynamic DT990 Pro | KEYBOARD Zoom75 (KTT Strawberry w/ GMK British Racing Green keycaps) | MOUSE  Cooler Master MM711 (White) MONITOR HP X32 1440p 165hz IPS
WORK RIG "OVERPRICED BRICK"
Mac Studio (M2 Ultra / 128GB / 1TB) | HEADPHONES  AirPods Pro 2 | KEYBOARD Logitech MX Mechanical Mini | MOUSE  Logitech MX Master 3S MONITOR 2x Dell 4K 32"
SECONDARY RIG "ALCATRAZ"
CPU i7-4770K OC @ 4.3GHz | COOLING Cryorig M9i (review| MOTHERBOARD ASUS Z87-PROGPU Gigabyte 1650 Super Windforce OC | RAM  16GB Crucial Ballistix Sport DDR3 1600 MHzSSD Samsung 860 Evo 512GB | HDD Toshiba 3TB 7200RPMPSU EVGA SuperNOVA NEX 750WCASE  NZXT H230 | HEADPHONES  Sony WH-1000XM3  | KEYBOARD Corsair STRAFE - Cherry MX Brown | MOUSE  Logitech G602 MONITOR LG 34UM58-P 34" Ultrawide
HOLA NIGHT THEMERS
GET YOUR ASS ON NIGHT THEME
OTHER TECH I OWN:
MacBook Pro 16" [M1 Pro/32GB/1TB] | 2022 Volkswagen GTI | iPhone 14 Pro | Sony a6000 | Apple Watch Series 8 45mm | 2018 MBP 15" | Lenovo Flex 3 [i7-5500U, HD5500 (fastest on the forum), 8GB RAM, 256GB Samsung 840 Evo] | PS5, Xbox One & Nintendo Switch [Home Theater setup] | DJI Phantom 3 Standard | AirPods 2 | Jaybird Freedom (two pairs) & X2 [long story, PM if you want to know why I have 3 pairs of Jaybirds]
For that amp+DAC you should get the HD600 or HD650. At the very least, that's an amp that excels with high impedance headphones.
To guide his decision, you should decide what kind of sound you want. If you don't know, just get one and see if you like it. Sell it and try again if you don't. You've probably got a 60% chance of success the first time around.
What's the open box price for them? I'd just pick between the elear, hex, or ether. El-8 is not even the same league as the rest, and lcd2 is destroyed by the elear with better build and comfort and overall sound quality (except for the slight dip in upper mid).
I'd get the Ether or Elear. HEX if the price is right.
IMHO the Lcd2 have nothing on either of the rest and the El8 are, like already mentioned, on a way different (lower)  level.
Are you sure that you wanna blow that much money on a headphone though? Have you done enough testing that you can justify that? Because there are already headphones at like $500 price tag that are insanely good.
Gaming HTPC:
Desktop PC:
Boss-NAS [Build Log]:
Synology-NAS:
DS920+
Audio Gear:
Reviews and Stuff:
Useful Links:
If the open-box headphones are >$500, get some Sennheiser HD 700s instead. Not the crazy 1K+ HD800s but still very good and super sexy
HOLA NIGHT THEMERS
OTHER TECH I OWN:
Why hd700 when hd600/650 are better and cheaper? Don't recommend it just because it's a bigger number...
The LCD-2 are  about 800, and the HEX and ether are around the same price of 1500. So all but the lcd are around the same price. I have tried the lcd-2 and elear and found the lcd-2 a lot more crisp and punchy then the elear but the elears are gor sure more comfortable.
Yes ive tested the lcd-2 and the elear and they gave me a sound I def would want over the 500 dollar price range cans
Okay good, fair enough. Have you tested the Ether and HEX though? Because I'd definitely recommend so. But as for the HEX, the v2 are available soon so I'd definitely wait for that even though the drivers are the same.
I find the Lcd2 to be way to uncomfortable for being a flagship high end can, whereas the Ether with a similar design are much much better and imho also better sounding.
The price difference is quite massive on the other hand. Have you also checked the Ether Flow? They're like an upgraded version.
Gaming HTPC:
Desktop PC:
Synology-NAS:
DS920+
Audio Gear:
Reviews and Stuff:
Useful Links:
oh idk if the 600/650 are better never tried either. I've tried the 700 and 800 though (at a store, I don't own either) and they were both phenomenal. I'm by no means an audiophile though as I couldn't really hear too much of a difference between the two.
If the 600/650 are really better than go for it
HOLA NIGHT THEMERS
OTHER TECH I OWN:
I have not tested the other two pairs as I was just planning on buying it from a local store(headphonebar) but I will look into it. My budget is about 1500 if I need to buy a high end pair.
Be careful about stating that price has anything to do with the sound signature.
What amp were you using for these headphones?
i am using a schiit valhalla and schiit bitfrost
Yeah, I read that part. That's the amp you used to audition the headphones?
yup
