Does this build supply enough power for US$1200?
hpotter134
Go to solution Solved by Trav_X,
2 minutes ago, hpotter134 said:
Some people sent me builds with a 1070, like this one http://pcpartpicker.com/list/Vdhh7h
See, that's a good build although that's a weird garbage SSD. That one also assumes you're paying $30 for Windows instead of buying a full license (buying a key and ripping the installation files).
http://pcpartpicker.com/list/gyhh7h
i came up with this, keeps the case you wanted and stuff but adds a 1070 and you can throw in an optical drive into that build too
1 minute ago, hpotter134 said:
Okay, but instead of higher costs going liquid, should I cut down some other costs and go with a 1070? There are builds for $1200 that have a 1070.
eh... you could... but you would have to cut down on a lot of stuff. I'm putting a list together right now.
Skyggeis Specs:
CPU: Intel Core i7-6700K 4.0GHz Quad-Core Processor
CPU Cooler: CRYORIG H5 Ultimate 76.0 CFM CPU Cooler
Motherboard: MSI Z170A SLI PLUS ATX LGA1151 Motherboard
Memory: Corsair Vengeance LPX 16GB (2 x 8GB) DDR4-3000
Storage: Samsung 850 EVO 250GB 2.5" Solid State Drive
Storage: Western Digital Caviar Blue 1TB 3.5" Hard Drive
Video Card: Zotac GeForce GTX 1070 8GB AMP! Extreme
Case: Phanteks ECLIPSE P400S ATX Mid Tower Case Satin Black
PSU: Corsair RMx 750W 80+ Gold Certified Fully-Modular PSU
WiFi Card: Gigabyte GC-WB867D-I REV 4.2
Case Fan: Aerocool DS 140mm Black 93.4 CFM
Other: Coolermaster VGA Holder
Other: Phanteks LED Strip 1M
Other: Phanteks Fan Splitter
Monitor: Dell S2716DG
You could probably fit that in. Also, if you considered it, getting an i5-6500 if you're not going to overclock anyway wouldn't be a bad idea. In the smaller form factor, overclocking will pretty much be limited anyways unless you fit a H100i in your 250D down the road (which will definitely increase noise), getting a 6500 is better since you won't need a strong cooler anyway.
MSI GE72 Apache Pro-242 - (5700HQ : 970M : 16gb RAM : 17.3" : Win10 : 1TB HDD : Razer Anansi : Some mouse) - hooked up to a 34UM58-P (WFHD) in dual screen
iPad Air 2 (for school)
iPhone 6
Xbox One Forza 6 Limited Edition Blue
Okay, I will take this into account. Thanks!
http://pcpartpicker.com/list/BxwLcc
Just barely made it. The NZXT case only has 2 fans, so you may have to buy more... but I DID IT!
Skyggeis Specs:
iPhone 6
Works, but Mid tower, and ITX, a bit weird... but some kind of fractal design define nano s and that works. Thanks!
OOOPS. *facepalm* Yeah. Switch out the case.
Skyggeis Specs:
Thanks! I will update my list with something along the lines of this. Thanks again.
No problem :D if you do get a 1070, have fun with it, it's a beast card, basically one of the top three cards on the market right now. And I'm sitting here with my 970M laptop GPU xD good luck with the building
iPhone 6
its not a random garbage ssd. http://www.tomshardware.com/reviews/crucial-mx300-ssd-review,4723-4.html
