Does this build supply enough power for US$1200?
hpotter134
Go to solution Solved by Trav_X,
2 minutes ago, hpotter134 said:
Some people sent me builds with a 1070, like this one http://pcpartpicker.com/list/Vdhh7h
See, that's a good build although that's a weird garbage SSD. That one also assumes you're paying $30 for Windows instead of buying a full license (buying a key and ripping the installation files).
http://pcpartpicker.com/list/gyhh7h
i came up with this, keeps the case you wanted and stuff but adds a 1070 and you can throw in an optical drive into that build too
I am thinking of an upgrade to my pretty crappy laptop so I can play games at 3440x1440 at ~60fps. This part list I am conceiving is in an ITX form factor. I would also like to know if an upgrade to an nvidia card is worth it on a freesync monitor.
The build: http://pcpartpicker.com/list/ZPKv4C
I am also getting the unlocked version of the i5 6600 for possible overclock ability, and resale value in the future. A z170 board is also used for the fact that there aren't any good non z170 ITX boards I heard of that also have WiFi connectivity.
So, is this build decent for US $1200?'
*Even though pcpartpicker says the MSI board is not compatible with 2280 m.2, reviews state that electrical tape can be used to secure larger sizes.
There is no 6600. Only 6500 and 6600k. And... I wouldn't go for water cooling at this price point. Take a look at the Cryorig H5, H7, C1, Noctua DH15, and some other better cooling solutions
Skyggeis Specs:
CPU: Intel Core i7-6700K 4.0GHz Quad-Core Processor
CPU Cooler: CRYORIG H5 Ultimate 76.0 CFM CPU Cooler
Motherboard: MSI Z170A SLI PLUS ATX LGA1151 Motherboard
Memory: Corsair Vengeance LPX 16GB (2 x 8GB) DDR4-3000
Storage: Samsung 850 EVO 250GB 2.5" Solid State Drive
Storage: Western Digital Caviar Blue 1TB 3.5" Hard Drive
Video Card: Zotac GeForce GTX 1070 8GB AMP! Extreme
Case: Phanteks ECLIPSE P400S ATX Mid Tower Case Satin Black
PSU: Corsair RMx 750W 80+ Gold Certified Fully-Modular PSU
WiFi Card: Gigabyte GC-WB867D-I REV 4.2
Case Fan: Aerocool DS 140mm Black 93.4 CFM
Other: Coolermaster VGA Holder
Other: Phanteks LED Strip 1M
Other: Phanteks Fan Splitter
Monitor: Dell S2716DG
1. Don't get that SSD. It's M.2 size, but it runs at regular SATA SSD speeds. Just spend the $90 on getting like a 500gb 2.5 inch drive, itll be the same speeds but more storage, and that case is big enough where you don't need M.2
2. Get a Cryorig H7 instead of the be quiet cooler if it fits in your 250D. Much better cooler, in terms of performance, aesthetics, mounting, and acoustics.
MSI GE72 Apache Pro-242 - (5700HQ : 970M : 16gb RAM : 17.3" : Win10 : 1TB HDD : Razer Anansi : Some mouse) - hooked up to a 34UM58-P (WFHD) in dual screen
iPad Air 2 (for school)
iPhone 6
Xbox One Forza 6 Limited Edition Blue
http://www.newegg.com/Product/Product.aspx?Item=N82E16819117562
that is an i5 6600
also the cooler isn't an aio watercooler, it is an air cooler
and to be more specific, should I look for a more powerful gpu in my build, for $1200
The i5 6600 exists: http://ark.intel.com/products/88188/Intel-Core-i5-6600-Processor-6M-Cache-up-to-3_90-GHz
And he selected an air cooler so I'm not sure why you're saying to not go for water cooling?
'Fanboyism is stupid' - someone on this forum.
Be nice to each other boys and girls. And don't cheap out on a power supply.
CPU: Intel Core i7 4790K - 4.5 GHz | Motherboard: ASUS MAXIMUS VII HERO | RAM: 32GB Corsair Vengeance Pro DDR3 | SSD: Samsung 850 EVO - 500GB | GPU: MSI GTX 980 Ti Gaming 6GB | PSU: EVGA SuperNOVA 650 G2 | Case: NZXT Phantom 530 | Cooling: CRYORIG R1 Ultimate | Monitor: ASUS ROG Swift PG279Q | Peripherals: Corsair Vengeance K70 and Razer DeathAdder
I'll look into a 500gb ssd, but I'm not sure any are available for less than $130
Also the Cryorig H7 is too big for the case, according to reviews stating 140mm maximum height and product page saying 95mm height maximum.
that is an i5 6600
Oops...
Skyggeis Specs:
I'm sorry. I don't know what's going through my head right now. I'm typing an essay while doing this at the same time.
Skyggeis Specs:
Haha it's okay, just type your essay.
1 minute ago, PCNoobie said:
Sadly no wifi on that mobo., but ofc that can be changed out
Is the PSU any good? 50 dollars make me a bit suspicious on its quality, but its not like I know anything about PSUs, you tell me.
Neat build.
Neat build.
You can use a PCIe or USB dongle for wifi. Sometimes it's actually faster that way.
Skyggeis Specs:
I will just use a different mobo instead. But running the 1070 on a freesync monitor, is tearing a big problem?
It's tier 3 psu, so it won't burn your pc at least.
Here is what I would suggest then, made quite a few changes for the better and stayed in budget, only went up $5. The 650w G2 is a great PSU, but SUPER overkill. Your PC will only sip barely 300 watts max + a bit for overclocking, so this CXM will be perfect, it's smaller, still quiet, and has good efficiency and a good quality OEM. Gives you an extra $45 to work with as well. Check this build out. Since you can't fit good tower CPU coolers, looks like your best bet at performance is an AIO.
CPU: Intel Core i5-6600K 3.5GHz Quad-Core Processor  ($227.99 @ SuperBiiz)
CPU Cooler: Corsair H55 57.0 CFM Liquid CPU Cooler  ($59.99 @ B&H)
Memory: Corsair Vengeance LPX 16GB (2 x 8GB) DDR4-2133 Memory  ($67.99 @ Newegg)
Storage: A-Data Premier SP550 480GB 2.5" Solid State Drive  ($109.99 @ NCIX US)
Video Card: MSI Radeon RX 480 8GB GAMING X Video Card  ($279.98 @ NCIX US)
Case: Corsair 250D Mini ITX Tower Case  ($79.99 @ Amazon)
Power Supply: SeaSonic 520W 80+ Bronze Certified Fully-Modular ATX Power Supply  ($54.99 @ Newegg)
Optical Drive: Asus DRW-24B1ST/BLK/B/AS DVD/CD Writer  ($17.88 @ OutletPC)
Operating System: Microsoft Windows 10 Home OEM 64-bit  ($85.70 @ My Choice Software)
Case Fan: be quiet! Pure Wings 2 51.4 CFM  120mm Fan  ($10.90 @ Newegg)
Case Fan: Noctua NF-R8 redux-1800 PWM 31.4 CFM  80mm Fan  ($13.88 @ OutletPC)
Other: MSI Gaming Z170I Gaming Pro AC LGA 1151 Mini ITX Intel Motherboard  ($160.00)
Total: $1194.06
Generated by PCPartPicker 2016-10-03 22:02 EDT-0400
iPhone 6
It'll just work as a normal monitor. G-sync is expensive and is way outside of your budget. And my own. :D
Skyggeis Specs:
Total: $1194.06
Liquid cooling, hm... I will have to think about it. Is it a quiet alternative? I would rather have a quiet pc than one that overclocks very well.
I mean... pumps can be noisy too. There are loud air coolers and quiet ones and there are loud liquid coolers and quiet ones.
Skyggeis Specs:
If you want quiet, then the be quiet cooler you had or a Cryorig H7 would be fine. Liquid coolers don't add much noise, especially if you set a fan curve on the fan on the radiator, but technically liquid can never be as quiet as air. You said earlier you could have overclockability, and you won't have much at all on the be quiet but the liquid would give you a decent amount of headroom for OC'ing.
iPhone 6
http://www.newegg.com/Product/Product.aspx?Item=N82E16835181029
30 dbs make me a bit worried... but I will think about it. A stock clocked 6600k shouldn't bottleneck a 1070... right?
Okay, but instead of higher costs going liquid, should I cut down some other costs and go with a 1070? There are builds for $1200 that have a 1070.
