Hey there, so yesterday and today my PC has been running as slow as I've ever seen, and I mean, after booting into Windows I cant even use the taskbar without the process crashing, now whenever I was able to get Task Manager up it showed that my disk usage was at 100% and it was always caused by windows services one way or another, however I couldn't find a way to disable them
Is it possible this is a virus? If so how do I go about removing it when I can barely use my pc?
 | CPU: AMD FX 8350 + H100i | GPU: AMD R9 290X + NZXT Kraken | RAM: HyperX Beast 2033 16GB | PSU: EVGA G2 | MOBO: ASRock 970M |
| CASE: Corsair Carbide 88R |STORAGE: 1x WD Black | KEYBOARD: Corsair K70 | MOUSE: R.A.T 9 |
SOMETIMES LOSING THE BATTLE, MEANS YOU CAN WIN THE WAR
https://linustechtips.com/topic/669644-pc-suddenly-running-incredibly-slowly/
1 minute ago, ShadowTechXTS said:
If you have another computer, plug the hard drive/SSD into that and backup, then reinstall Windows.
I don't have another desktop and no way to connect the HDD to my laptop
this could be caused by a few things:
1. Drive failure (or the begginings thereof)
2. Virus (unlikely, but possible)
3. Recently installed software has stuff in your startup that you don't know about
4. Old windows install
In which case, there are a few solutions:
check out the startup tab of task manager, it lists everything that starts when you boot up, and its impact on time.
You can also run a virus scan (I recommend MalwareBytes)
Check your drive's health
Reinstall windows (Generally a good idea to do every now and then, it makes things smoother)
Different PCPartPickers for different countries:
UK-----Italy----Canada-----Spain-----Germany-----Austrailia-----New Zealand-----'Murica-----France-----India
10 minutes ago, Stardar1 said:
Well, with an i7, GTX 1080, Full tower and flashy lights, it can obviously only be for one thing:
Solitaire.
Best softwre to check drive health?
You could get a SATA>USB dock, but I'd check the drive health first as @Stardar1 said.
https://www.amazon.com/Thermaltake-Sata-HDD-Docking-Station/dp/B0012Z3MKW
i like linux
I wouldnt know, but I'd check startup processes and MalwareBytes first anyways.
Solitaire.
Startup processes I checked a long time ago, and malwarebytes I'm doing now
