So when i use my pfsense router i get this error on this page
translated its : The requested page is not avalible (jwplayer)
but when i use vpn with pfsense or use isp router it works fine
so what to do on the pfsense router to fix it
http://www.npo.nl/npo3 <- page for if needed
https://linustechtips.com/topic/669179-pfsense-jwplayer-problem/
Just now, Eniqmatic said:
Do you have any other packages installed or is it a base install with nothing configured?
Youre a genius now the new problem the thing blocks it when i use squid for cache sites i whitelisted npo.nl but still doesnt play withotu squid it does perfectly!
https://linustechtips.com/topic/669179-pfsense-jwplayer-problem/#findComment-8631725
Its possible that the video does not actually load from that URL. You would need to check the real-time squid logs as you load the page to see what is being requested.
System/Server Administrator - Networking - Storage - Virtualization - Scripting - Applications
https://linustechtips.com/topic/669179-pfsense-jwplayer-problem/#findComment-8631744
I give up looked for over an hower with wireshark blocked over 100th ips still not loading
https://linustechtips.com/topic/669179-pfsense-jwplayer-problem/#findComment-8632221
Yes you need to enable the access logs though to produce anything readable, go back to the first tab, go down till you find the tick box that says "enable access logs" and ensure the location is set to the default (it tells you). Turn this on, then go back to the realtime tab. Now whenever you reload a page, all requested URL's will appear automatically (no need to refresh the pfsense page).
https://linustechtips.com/topic/669179-pfsense-jwplayer-problem/#findComment-8632663
Oke, next problem the npo.nl stream server gives a new ip all the time is it possible to allow an ip range of do i have to type out all 912385901835 ip adresses because its all the time  195.121. x.x the X changes all the time
https://linustechtips.com/topic/669179-pfsense-jwplayer-problem/#findComment-8640170
Ah, that is there problem then. They appear to have hard-coded IP addresses in to the videostream, which is... stupid.
So its not possible? i typed in every single ip of them but they still come in the log even the once witch are on the do not cache list
https://linustechtips.com/topic/669179-pfsense-jwplayer-problem/#findComment-8640492
