Hello, im looking to buy full system for my little brother. He is 10 yrs old and he is looking to play lower end titles like Civ V, scrap mechanic, modded Minecraft and a few triple a titles like TF2. I wonder if anyone has any reccomendations for parts with my budget of 800 dollars for the whole stuff, where about 600 dollars goes for the hardware itself. Need help desperatly!
https://linustechtips.com/topic/668094-entry-level-pc/
https://pcpartpicker.com/user/Flamiemeister/saved/#view=gT6hMp
Thy shall do you good
If you have a prebuilt and you can find the windows registry sticker on the case, you can use that for when you install windows.
http://pcpartpicker.com/list/Mf3Zcc My build
R.I.P Donny- Got banned. We will always remember your spamming of "Cancerbooks"
iPhones are like 1 ply toliet paper with a logo slapped on them and years old hardware in them- A Wise Man
https://linustechtips.com/topic/668094-entry-level-pc/#findComment-8620036
Easy build a solid pc from used parts for that. Older quad core some cheap 8gb ram a half decent psu then throw the rest into a gpu ?
Main system:
i7 6700k @4.8ghz 1.45v
ROG Maximus Hero VIII
Gigabyte G1 980ti Sli @1500 ghz
Samsung 950 pro 512gb
16gb G.Skill Ripjawz V @3400mhz
Corsair H115i 280mm AIO
Corsair 400c Case
Corsair RM1000i
Backup/Older/Toys:
Intel i3 6100 @4.6ghz 1.52v
Asrock B150M Pro4/Hyper
Intel 750 series 400gb
Radeon Rx 470 XFX
Thermaltake Water 3.0 360mm AIO
inWin 303 case
AMD Phenom II x4 940 @3.9ghz 1.65v
Gigabyte 780g mobo
Corsair H100 240mm AIO
Corsair Dominiator 8gb DDR2 @1066
Evga GTX 750ti FTW @1450mhz
Thermaltake Matrix case (modded)
"The best way to look stylish on a budget is to try second-hand, bargain hunting, and vintage"
https://linustechtips.com/topic/668094-entry-level-pc/#findComment-8620040
From the front page of pcpartpicker.com
this is an entry level build that should be able to handle these games. Linus also did a video called the ultimate value gaming build that you could check out. For playing low end games like minecraft, csgo, and probably civ v these should be good.
The linked one on pc part picker should leave you some room to buy a decent monitor and some good peripherals.
https://linustechtips.com/topic/668094-entry-level-pc/#findComment-8620042
https://linustechtips.com/topic/668094-entry-level-pc/#findComment-8620046
Why not switch out that 845 for an 860K or 880K?
The Full Pounder Korbger (main PC):
CPU: AMD Ryzen 5 7600X | CPU Cooler: Deepcool AK500 ZERO DARK | MOBO: Gigabyte B650M AORUS ELITE AX | RAM: G.Skill Flare X5 32GB DDR5-5600 | Storage: Kingston NV2 1TB NVMe SSD, 2x Inland Professional 1TB SATA SSDs | GPU: ASRock Challenger Radeon RX 9070 | Case: Fractal Design North | PSU: Montech CENTURY II 850W 80+ Gold
Sheer Will and Spite (home server):
CPU: AMD A10-7870K | CPU Cooler: Stock AMD Cooler | MOBO: ASRock FM2A88X PRO3+ | RAM: Crucial 16GB DDR3-1600 | Storage: Kingston SSDNow S50 16GB SSD, Crucial MX100 512GB SSD, Seagate BarraCuda 2TB HDD, Western Digital Blue 2TB HDD, Seagate BarraCuda 1TB HDD, Seagate 1TB hybrid drive | GPU: Sparkle ECO Arc A310 | Case: Apevia X-Plorer | PSU: Thermaltake Smart Pro RGB 750W 80+ Bronze | Expansion Card: VOGZONE 2.5Gb PCIe Network Card
The Curb Stomp Coin-Op (MAME Machine):
CPU: AMD Ryzen 5 1600 | CPU Cooler: AMD Wraith SPIRE | MOBO: Gigabyte GA-AB350N-Gaming WIFI | RAM: Patriot Signature Premium 16GB DDR4-2666 | Storage: PNY CS900 240GB SSD, Samsung 860 Evo 2TB SSD | GPU: Gigabyte GeForce GTX 1050 Ti | Case: Homemade Arcade Cabinet | PSU: Corsair RM750x 750W 80+ Gold | Monitor: ONN 21.5" 1080p 100Hz Freesync
Bazzite Box (HTPC):
CPU: AMD Ryzen 5 3600X | CPU Cooler: Wraith Spire | MOBO: ASRock AB350 Gaming-ITX/ac | RAM: Corsair Vengeance RGB 16GB DDR4-3000 | Storage: WD Black SN770 1TB NVMe SSD | GPU: PowerColor Fighter Radeon RX 6600 XT | Case: PowerTrain X-GAMER X100 | PSU: MSI MAG A650BN 650W 80+ Bronze
https://linustechtips.com/topic/668094-entry-level-pc/#findComment-8620048
That has monitors n everything
https://linustechtips.com/topic/668094-entry-level-pc/#findComment-8620050
The build I created will work well OP. Its 700 and has all the essentials
https://linustechtips.com/topic/668094-entry-level-pc/#findComment-8620067
http://pcpartpicker.com/list/KCdzPs
https://pcpartpicker.com/list/by_merchant/
 Intel Core i5-6600K 3.5GHz Quad-Core Processor
 Cooler Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler
Motherboard Asus Z170-E ATX LGA1151 Motherboard
Memory G.Skill Ripjaws V Series 16GB (2 x 8GB) DDR4-2400 Memory
Storage Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive
Video Card Gigabyte GeForce GTX 1060 6GB 6GB WINDFORCE OC 6G Video Card
Case NZXT Source 210 (Black) ATX Mid Tower Case
Power Supply EVGA 500W 80+ Bronze Certified ATX Power Supply
Base Total:$821.77
Mail-in Rebates:-$30.00
Shipping:$1.99
Total:$793.76
I would buy a open box asus z170 a from newegg it will be cheaper.
EDIT: This is if you want to stick with your current monitor and keyboard and mouse
CPU-i7 6700k O.C. 4.6Ghz-Motherboard-Asus z170-a-RAM-24gb DDR4-GPU-EVGA GTX 1080 FE-Case-Corsair 400c (white)-Storage-HDD: 2xWD Blue 1TB SSD: PNY SSDSC120GLC709B121-510 120GB-PSU-1000 watt coolermax-Display-ASUS VG248QE Black 24" 1080p 144 Hz -Cooling-Corsair H115i-Keyboard-G.Skill KM780 Cherry MX blues (Red backlight)-Mouse-Logitech G602-Sound-Logitech 5.1 z506
Need a budget headphone for under 100$? Sennheiser HD 558 Headphones
Got a Skylake CPU (k) Here is a guide to OC it!
https://linustechtips.com/topic/668094-entry-level-pc/#findComment-8620075
Bad idea. What if it's damaged during shipping, or what if it was returned for having problems, and resold?
https://linustechtips.com/topic/668094-entry-level-pc/#findComment-8620089
CPU: AMD Athlon X4 880K 4.0GHz Quad-Core Processor  ($84.99 @ SuperBiiz)
Motherboard: Gigabyte GA-F2A68HM-H Micro ATX FM2+ Motherboard  ($44.98 @ OutletPC)
Memory: Mushkin Essentials 8GB (1 x 8GB) DDR3-1600 Memory  ($31.98 @ OutletPC)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($45.71 @ OutletPC)
Video Card: PowerColor Radeon RX 460 4GB Red Dragon Video Card  ($123.98 @ Newegg)
Case: Rosewill FBM-02 MicroATX Mini Tower Case  ($24.99 @ Newegg)
Power Supply: EVGA 500W 80+ Bronze Certified ATX Power Supply  ($43.33 @ OutletPC)
Operating System: Microsoft Windows 10 Home OEM 64-bit  ($85.70 @ My Choice Software)
Monitor: HP 22cwa 21.5" 60Hz Monitor  ($99.99 @ Amazon)
Keyboard: Cooler Master CM Storm Devastator Gaming Bundle Wired Gaming Keyboard w/Optical Mouse  ($29.99 @ Amazon)
Headphones: Logitech G430 7.1 Channel  Headset  ($39.99 @ Best Buy)
Speakers: Logitech Z213 7W 2.1ch Speakers  ($24.79 @ Amazon)
Total: $680.42
Generated by PCPartPicker 2016-09-28 11:24 EDT-0400
880K, has only 1 stick of 8GB RAM so you have an open slot later.  That way, if you upgrade it, you don't have to discard any.  I got you a nice 22 inch 1080p IPS monitor.  Speakers w/subwoofer, and a headset.  Also a pretty decent gaming keyboard/mouse combo.
Bazzite Box (HTPC):
https://linustechtips.com/topic/668094-entry-level-pc/#findComment-8620110
1 minute ago, EntryLevelScrub said:
The GPU is not a big issue so i can get by by something like a gt 760
There is no GT 760, unless you meant the 730.  But either way, for not much more, the RX 460 will last much longer.  Look at the build I posted, it includes everything, hardware, peripherals, OS, for $120 less than your total overall $800 budget.
Bazzite Box (HTPC):
https://linustechtips.com/topic/668094-entry-level-pc/#findComment-8620119
It's sold and certified by new egg plus they are actually really good and replacing open box items damaged during shipping as well if its not working when arrived. My asus z170 a was an open box from newegg works like a charm ;p
https://linustechtips.com/topic/668094-entry-level-pc/#findComment-8620126
8 minutes ago, EntryLevelScrub said:
Thank you for these reccomendations, but i think that i would want an i5 so i want an i5 6400 as a baseline
CPU: Intel Core i5-6400 2.7GHz Quad-Core Processor  ($174.99 @ SuperBiiz)
Motherboard: Gigabyte GA-H110M-A Micro ATX LGA1151 Motherboard  ($44.99 @ Amazon)
Memory: G.Skill NT Series 8GB (1 x 8GB) DDR4-2133 Memory  ($32.98 @ Newegg)
Case: Rosewill FBM-05 MicroATX Mini Tower Case  ($22.99 @ Newegg)
Power Supply: EVGA 450W 80+ Bronze Certified ATX Power Supply  ($38.99 @ SuperBiiz)
Keyboard: Cooler Master CM Storm Devastator Gaming Bundle Wired Gaming Keyboard w/Optical Mouse  ($29.99 @ B&H)
Total: $765.09
Generated by PCPartPicker 2016-09-28 11:33 EDT-0400
Core i5 as the base.
Bazzite Box (HTPC):
https://linustechtips.com/topic/668094-entry-level-pc/#findComment-8620145
Total: $765.09
I'll find the link to reddit where you can get an oem key of 10 for $30
https://linustechtips.com/topic/668094-entry-level-pc/#findComment-8620152
I was thinking of using Kinguin, since it's only like $25, but I know some people on here are weary of it.
Bazzite Box (HTPC):
https://linustechtips.com/topic/668094-entry-level-pc/#findComment-8620156
