Hiya all!
So, I'm in the market for a new laptop around the $1500 mark. I have a gaming desktop already so I'm mostly looking for something that can at a minimum run Autodesk Maya well, play QHD or higher video, and is just really effective for all around productivity. Being able to play games would be a plus, but I primarily play Warframe and games of that nature that aren't too terribly intensive. The main things specwise that I'm worried about are battery life, portability, and not looking like a generic slice or ugly brick (looking at you, clevo). i7 and a decent GPU (970/60M or 1060 if it can cool well) are musts because of the CAD and heavy art workflows I go through for modeling and video rendering. I've been looking at Razer because let's face it, they look amazing, but the heat problems while gaming (which I'm not sure whether they would transfer over to modeling/drawing or not) and battery life seem to be an issue for a lot of people. MSI makes it hard to tell on their site whether the laptops are thick or thin, which makes me a little dubious. I'm of course still open to both of those possibilities if y'all think they'd work for me
Anyway, any suggestions are welcome! Thanks in advance!
https://linustechtips.com/topic/667402-need-some-advice/
5 minutes ago, velvetxcat said:
Hiya all!
http://www.newegg.com/Product/Product.aspx?Item=N82E16834152944
https://linustechtips.com/topic/667402-need-some-advice/#findComment-8613227
Here's 3 different choices to think about, personally I'd go with the MSI option as it comes with an SSD. http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&N=100167732 4084 8000 4814 601211658&IsNodeId=1
Ryzen 5 1500X @ 3.9GHz On 1.3625V | MSI B350M Gaming Pro | 16GB G.Skill Ripjaws V DDR4 3200MHz | 3GB MSI GTX 1060 Gaming X 2063MHz Core 9408MHz Mem | EVGA G2 550W | 250GB Samsung 850 EVO | Windows 10 Home 64-bit Version 1903 (Build 18362.295) | MasterCase Pro 3
https://linustechtips.com/topic/667402-need-some-advice/#findComment-8613242
9 minutes ago, r00tH4cK3r said:
Thanks for the response! Only thing I'm a little shaky on for that one and ones like it are the >1 in thickness and the >5 pound weight, which ends up being a lot (from toting a macbook for 3 years, and not a new one :( )
https://linustechtips.com/topic/667402-need-some-advice/#findComment-8613248
XPS15. Pretty much the only choice here. Everything else recommended above have issues.
Razer blade will have problems when you're rendering.
Laptop Main
(Retired) Zbook 15: i7-6820HQ, M2000M, 32gb, 512gb SSD + 2tb HDD, 4k Dreamcolor
(Retired) Alienware 15 R3: i7-6820HK, GTX1070, 16gb, 512 SSD + 1tb HDD, 1080p
(Retired) T560: i7-6600U, HD520, 16gb, 512gb SSD, 1620p
(Retired) P650RS: i7-6820HK, 1070, 16gb, 512gb + 1tb HDD, 4k Samsung PLS
(Retired) MBP 2012 Retina: i7-3820QM, GT650M, 16gb, 512gb SSD, 1800p
https://linustechtips.com/topic/667402-need-some-advice/#findComment-8615124
Thanks for the input! XPS 15 is indeed looking like the best option, as much as I'm SO unwilling to get a dell because frankly my only experience with dells is just totally junk machines that're absolutely worthless, but I'll definitely put it up there on the list as it seems very highly recommended and I can see from your stats you know what you're talking about :D
https://linustechtips.com/topic/667402-need-some-advice/#findComment-8618099
That's not a great measurement of knowledge. Just judge every post by it's merits. You'll also want to grab the refurb one's on ebay with premier warranty from Dell. http://www.ebay.com/itm/DELL-XPS-15-9550-15-6-FHD-1080P-INTEL-i7-6700HQ-16GB-512GB-SSD-GTX-960M-PROSPRT-/201654654998?hash=item2ef38dd816:g:lioAAOSwJb9Wqidt
Laptop Main
https://linustechtips.com/topic/667402-need-some-advice/#findComment-8618187
