Fixing this would involve accounting for quite a few edge cases, such as if you were editing more than one post at once, and it would probably require some fairly major code changes to make it work. I agree that it is slightly annoying, but it's not too often that you need to add a new quote to an existing post, and it's not too hard to just click the byline of the quote, press Ctrl+C (or Ctrl+X), then paste it into the edit editor.
Unfortunately, the probability of the feasibility of this idea even being assessed by the devs, let alone it being implemented, is basically zero, and it's not something that I can modify, so it's probably not going to happen.
PS. Moved to feature suggestions, because it's not a bug.
HTTP/2 203
https://linustechtips.com/topic/666264-quote-problem/#findComment-8600933
Ok, thanks for the fast reply atleast :)
https://linustechtips.com/topic/666264-quote-problem/#findComment-8600943
