I recently built my own PC. Then after a forced shutdown it would not power on. So I took it to a repair shop and was told to replace the PSU; I did and it did not help. So after doing some research I "breadboarded" the motherboard and found out that if I unplug one stick of RAM it would work. I then unplugged everything to put it back in the case and when I powered it up it would not show anything on the monitor. So I unplugged everything from the back: monitor, keyboard, and mouse and it worked. I plugged everything in one at a time and it still worked. Is this a motherboard issue?
https://linustechtips.com/topic/664775-random-issue/
How much RAM, across how many DIMMs, and what mobo? Need specific info please so the hardware gurus can help you out.
-----> Official Unofficial Favorite Keyswitch Type Survey <-----
 OWNER OF THE FASTEST INTEL iGPU ON LTT UNIGINE SUPERPOSITION [lol]
GAMING RIG "SNOWBLIND"
CPU i5-13600k | COOLING Corsair H150i Elite Capellix 360mm (White) | MOTHERBOARD Gigabyte Z690 Aero G DDR4 | GPU Gigabyte RTX 3070 Vision OC (White) | RAM  16GB Corsair Vengeance Pro RGB (White)SSD Samsung 980 Pro 1TB | PSU ASUS STRIX 850W (White)CASE  Phanteks G360a (White) | HEADPHONES  Beyerdynamic DT990 Pro | KEYBOARD Zoom75 (KTT Strawberry w/ GMK British Racing Green keycaps) | MOUSE  Cooler Master MM711 (White) MONITOR HP X32 1440p 165hz IPS
WORK RIG "OVERPRICED BRICK"
Mac Studio (M2 Ultra / 128GB / 1TB) | HEADPHONES  AirPods Pro 2 | KEYBOARD Logitech MX Mechanical Mini | MOUSE  Logitech MX Master 3S MONITOR 2x Dell 4K 32"
SECONDARY RIG "ALCATRAZ"
CPU i7-4770K OC @ 4.3GHz | COOLING Cryorig M9i (review| MOTHERBOARD ASUS Z87-PROGPU Gigabyte 1650 Super Windforce OC | RAM  16GB Crucial Ballistix Sport DDR3 1600 MHzSSD Samsung 860 Evo 512GB | HDD Toshiba 3TB 7200RPMPSU EVGA SuperNOVA NEX 750WCASE  NZXT H230 | HEADPHONES  Sony WH-1000XM3  | KEYBOARD Corsair STRAFE - Cherry MX Brown | MOUSE  Logitech G602 MONITOR LG 34UM58-P 34" Ultrawide
HOLA NIGHT THEMERS
GET YOUR ASS ON NIGHT THEME
OTHER TECH I OWN:
MacBook Pro 16" [M1 Pro/32GB/1TB] | 2022 Volkswagen GTI | iPhone 14 Pro | Sony a6000 | Apple Watch Series 8 45mm | 2018 MBP 15" | Lenovo Flex 3 [i7-5500U, HD5500 (fastest on the forum), 8GB RAM, 256GB Samsung 840 Evo] | PS5, Xbox One & Nintendo Switch [Home Theater setup] | DJI Phantom 3 Standard | AirPods 2 | Jaybird Freedom (two pairs) & X2 [long story, PM if you want to know why I have 3 pairs of Jaybirds]
https://linustechtips.com/topic/664775-random-issue/#findComment-8585889
Yeah, happens sometimes.
As long as it isn't happening repeatedly you should be ok.
If it happens again that you need to unplug all your USB stuff to power on then I would first test all your USB devices on another PC before changing your motherboard.
If it happens on another PC then one of your USB devices is defective, and you can use trial and error to find out which one.
But it is most likely the motherboard.
https://linustechtips.com/topic/664775-random-issue/#findComment-8585894
Interesting. I don't like your breadboarding of the mobo. That could really mess stuff up. But yeah, probably an issue with the motherboard chipset or USB bus controller if I had to guess. Check your warranty, and see if you can get a replacement for free.
I try to answer the best I can.
Please realize that 95% of issues can be solved through Google.  I'll try to help,  but you need to Google yourself.
https://linustechtips.com/topic/664775-random-issue/#findComment-8585902
