http://pcpartpicker.com/list/bcx4M8 Im going for a stealth look, I am looking at cable mod cables but im not sure what cables i need. By the way before you comment on the build i plan on upgrading the CPU later on if i get this. I know the motherboard isnt the best but i cannot stand the look of the other ones.
Edit - Black cables, sorry i forgot to specify.
https://linustechtips.com/topic/664493-cable-help/
get a better system before you make it look nice
Good luck, Have fun, Build PC, and have a Wii and PS2 as your only consoles.
NightHawk 3.0: R7 5700x @, B550A vision D, H105, 2x32gb Oloy 3600, Asrock RX9070xt Steel Legends, Corsair RM750X, 500gb 850 evo, 2tb rocket and 5tb Toshiba x300, 3x 6TB WD Black W10 all in a Obsidian 750D airflow.
GF PC: (NightHawk 2.0): R7 2700x, B450m vision D, 4x8gb Geli 2933, Sapphire RX 6700XT  Nitro+, CX650M RGB, Obsidian 350D
Skunkworks: R5 3500U, 16gb, 500gb 860 evo, Vega 8. HP probook G455R G6 Ubuntu 20. LTS
Condor (MC server): 6600K, z170m plus, 16gb corsair vengeance LPX, samsung 750 evo, EVGA BR 450.
Spirt  (NAS) ASUS Z9PR-D12, 2x E5 2620V2, 8x4gb, 24 3tb HDD. F80 800gb cache, trueNAS, 2x12disk raid Z3 stripped
HP probook 445R G6 review
"Stupidity is like trying to find a limit of a constant. You are never truly smart in something, just less stupid."
Camera Gear: X-S10, 16-80 F4, 35mm F1.4, Helios 44
https://linustechtips.com/topic/664493-cable-help/#findComment-8582659
its like 50-100$ right. get a better cpu then consider it
https://linustechtips.com/topic/664493-cable-help/#findComment-8582664
1 minute ago, Paytend01 said:
Yeah i know
Edit -  I just cannot stand the looks of the other Mini ITX motherboards
Well, its your loss then.
I5 4440//8gb Corsair Vengeance ddr3//Sapphire Radeon r9 380 4gb//ASUS h81m-plus//WD caviar blue 1tb//Cooler Master N200//Cooler Master G500
https://linustechtips.com/topic/664493-cable-help/#findComment-8582720
Thanks, any other cables i need? I know i need to pic up a Sata cable also.
Here are some braided SATA cables also from CableMod:
https://cablemod.com/product-category/sata-data-cables/
Might just want to pick up a cheap plastic one tho
https://linustechtips.com/topic/664493-cable-help/#findComment-8582740
