Using varibles to calculate
Angy
Hello,
I am doing some coding for a project in Java.
and I have multiple variables, is there an easy way to test if a variable is not entered into a JTextField, and calculate it?
Thanks!
i havent worked with Java and JTextFIelds in months, but i believe when nothing is entered, calling the getText() method will either return an empty string or null. so just have a test
String tField = textField.getText();
if(textField.getText() == null || tField.equals("")) {
	//do your computations
} else if(//next text field test, etc.) {
i may be completely wrong.
Rigs I've Built
The Striker i5 4590 @ 3.7 ||  MSI GTX 980 Armor X2 || Corsair RMX 750 || Team Elite Plus 8 GB || Define S || MSI Z97S SLI Krait
The Office PC i3 4160 @ 3.6 || Intel 4600 || EVGA 500B || G.Skill 8 GB || Cooler Master N200 || ASRock H97M Pro4
The Friend PC G3258 @ 4.3 || Sapphire R9 280X Tri-X || EVGA 600B || 8 GB Dell Ram || Cooler Master N200 || ASRock H97M- iTX/ac
The Mom Gaming PC A10-7890K @ 4.4 || iGPU + ASUS R7 250 ||  8 GB Klevv DDR3-2800 Mhz
This is not working
ActionListener actionListener = new ActionListener() {
        public void actionPerformed(ActionEvent e) {
        if (window == BASICINTEREST);      // basic interest calculator
        Pval = Double.parseDouble(card1P.getText());  // these retrieve the values out of the JTextFields
            Rval = Double.parseDouble(card1R.getText());
            Tval = Double.parseDouble(card1T.getText());
            Ival = Double.parseDouble(card1I.getText());
            Rval = Rval/100;
            ans =Double.parseDouble(new DecimalFormat("##.####").format(ans));  // formats the output to be 3 decimal places
            if(card1I.getText() == null || card1I.equals(""));     // tests if The I value is unknown and so on
            ans =  Pval * Rval * Tval;
            answerTxt.setText(String.valueOf(new Double(ans)));
            if(card1P.getText() == null || card1P.equals(""));
            ans = Ival/(Rval * Tval);
            if(card1R.getText() == null || card1R.equals(""));
            ans = Ival/(Pval * Tval);
            if(card1T.getText() == null || card1T.equals(""));
            ans = Ival/(Pval * Rval);
    calculate.addActionListener(actionListener);
@Angy please you [ code] tags.
                     ¸„»°'´¸„»°'´ Vorticalbox `'°«„¸`'°«„¸
`'°«„¸¸„»°'´¸„»°'´`'°«„¸Scientia Potentia est  ¸„»°'´`'°«„¸`'°«„¸¸„»°'´
            Rval = Rval/100;
            Rval = Rval/100;
you're asking if the varible is empty then do your code. You need to ask if it is not empty
if i != null
run code.
