So my room is pretty cold. I have a desktop, but its in another room. So my idea was to make a desktop dedicated to heating my room. Now here are my thoughts. Instead of me getting a 500W space heater I could just get a 500W desktop and do the same thing. So, here are the requirements and I need part suggestions:
1. Around $300-$400 USD. (I can go over if there is a huge performance gain for like $50 (like being able to get a GTX 960 for $100 used but a 980 for $150.))
2. Quiet (Want it to be pretty quiet)
3.Small (Would like to keep it on a shelf or something)
4. Great at F@H or Boinc. (My plan to generate the heat is to do F@H or something)
5. Power consumption doesn't matter
6. Used is great if I can get more for my buck.
So does anyone have any thoughts on what to get?
This will also be used as my guest PC so it probably needs to be able to run games
Breaking things 1 day at a time
https://linustechtips.com/topic/663492-project-space-heater/
Fx 9590 with Dual r9 295x2, and call the fire department while you are at it.
 •E5-2670 @2.7GHz • Intel DX79SI • EVGA 970 SSC• GSkill Sniper 8Gb ddr3 • Corsair Spec 02 • Corsair RM750 • HyperX 120Gb SSD • Hitachi 2Tb HDD •
https://linustechtips.com/topic/663492-project-space-heater/#findComment-8572240
Use an AMD 2 or 3 series GPU, like a 290. You may be able to get it cheap since bitcoin and other crypto currencies are dead.
Main Gaming Rig:
Core i7-4770, Cryorig M9i Cooler, ASUS B85M GAMER, 8GB HyperX Fury Red 2x4GB 1866MHz, KFA2 GTX 970 Infin8 Black Edition "4GB", 1TB Seagate SSHD, 256GB Crucial m4 SSD, 60GB Corsair SSD for Kerbal and game servers, Thermaltake Core V21 Case, EVGA SuperNOVA 650W G2.
Secondary PC:
i5-2500k OCed, Raijintek Themis, Intel Z77GA-70K, 8GB HyperX Genesis in grey, GTX 750 Ti, Gamemax Falcon case.
https://linustechtips.com/topic/663492-project-space-heater/#findComment-8572243
whatever the top of the line insaine AMD 8 core thing is right now and then quad SLI GTX 480s
Builds:
https://linustechtips.com/topic/663492-project-space-heater/#findComment-8572256
Just now, TubsAlwaysWins said:
Once again, don't think I can get 4 480s in my budget
then get one or two lol, they are crazy good for cooking bacon in your PC lol
Builds:
https://linustechtips.com/topic/663492-project-space-heater/#findComment-8572266
http://pcpartpicker.com/list/Zwr34C
and get a Thermi gpu like a gtx 480/580 usually go for $60-$70USD.
https://linustechtips.com/topic/663492-project-space-heater/#findComment-8572292
