Help for building my first own data server
Solved by Mikensan,
from what you said OP the data isn't important so redundancy or simply downtime isn't a big deal. So a raid 6 doesn't have a whole lot of benefit for you. Something like Windows storage spaces or flexraid with a parity disk will keep it simple and sufficient. The only time you might hit some speed drops is if 2 people want to transfer stuff off the server at the same time and that data just happens to be on the same disk, it will start slowing down but for streaming 1080p I don't expect 2 streams from a single disk to have any impact. As a media NAS you will be happy with that.
Now if you want to setup iscsi and run virtual machines off this NAS from another host, there's a lot more to consider ![]()
