http://pcpartpicker.com/list/RdHPFd
Ordering tomorrow or today! Please tell me if i've chosen a shitty or overpriced component. Not too sure about the psu, also not sure how quiet the h440 is.
Will it all fit together? Any compatability problems?
Thanks!
Main Rig
CPU: Ryzen 2700X
Cooler: Corsair H150i PRO RGB 360mm Liquid Cooler
Motherboard: ASUS Crosshair VII Hero
RAM: 16GB (2x8) Trident Z RGB 3200MHZ
SSD: Samsung 960 EVO NVME SSD 1TB, Intel 1TB NVME
Graphics Card: Asus ROG Strix GTX 1080Ti OC
Case: Phanteks Evolv X
Power Supply: Corsair HX1000i Platinum-Rated
Radiator Fans: 3x Corsair ML120
Case Fans: 4x be quiet! Silent Wings 3
https://linustechtips.com/topic/662867-ordering-tomorrow-today-help/
1 minute ago, Armakar said:
http://uk.pcpartpicker.com/list/
Thanks!
Thats a blank list......
Elemental
Intel i5 6500 @3.8ghz - 8GB HyperX - 600w Apex PSU - GTX 1060 G1 GIGABYTE 6GB - s340 Black - 240gb Toshiba Q300 - Cooler master TX3i - MSI z170-A PRO.
Old Build (sold for 290€)
Intel i3 540 @ 3.9ghz (On stock cooler, Hits 80c max) - 8gb ram - 500w power supply - P7H55-M LE  120gb SSD - Talius Drakko case
Project Frug 50$ Water loop
Laptops
13" Macbook Air - Alienware m14x r2 -  2009 15" Macbook Pro (I was give all of these and would never buy them myself)
Fixed. Thanks for letting me know haha
Main Rig
CPU: Ryzen 2700X
looks good to me, maybe a bit more ram? but apart from thats its perfect
Elemental
Laptops
what are you gonna use it for?
Elemental
Laptops
I'm not sure if I really need anything over 16GB. I'm gaming, stremaing and doing some VR - my 1070 has 8GB so I think 16 should be okay.
Main Rig
CPU: Ryzen 2700X
seems good
Elemental
Laptops
Just now, gtx1060=value said:
h440 is pretty good, i have it myself and it's fairly quiet especially if you get be quiet case fans
How are the default case fans on the h440?
To be honest, I didn't want to go with the h440. I was going to get a be quiet 800 / 600 because they are SO WELL build and come with 2 / 3 of be quiet's fans. I like the be quiet so much more, however i'm not sure if the orange theme to it would fit with my red theme or not, and the black/gray looks boring.
Main Rig
CPU: Ryzen 2700X
if you don't like the orange. the extra 40 dollars for be quiet fans is worth it. the h440's fans are ok but not really quiet if you want an extremely quiet computer
I have a nearly identical build as you, so if you want pics I can send you some. Besides that, the h440 is pretty good. The default fans are quite loud and non controllable (they are hooked up to a hub in the back that doesn't support voltage control. If possible , I would swap them out with some Noctua nff12. Besides that, everything about the case is great. I wasn't a fan of the polycarbonate window but I was able to replace to with an acrylic window they looks much better. The build is overall pretty quite, I can't hear anything from mine with headphones on.
******If you paste in text into your post, please click the "remove formatting" button for night theme users.******
CPU- Intel 6700k OC to 4.69 Ghz GPU- NVidia Geforce GTX 970 (MSI) RAM- 16gb DDR4 2400 SSD-2x500gb samsung 850 EVO(SATA) Raid 0 HDD- 2tb Seagate Case- H440 Red w/ custom lighting Motherboard - MSI Z170 Gaming A OS- Windows 10 Mouse- Razer Naga Epic Chroma, Final Mouse 2016 turney proKeyboard- Corsair k70 Cherry MX brown
Looks pretty good to me!
Main Rig: CPU i7-4790k / MOBO Asus Z97-Pro (Wifi-AC) / RAM 16GB HyperX Fury 1866 MHz / CPU COOLER Dark Rock 3 / GPU Asus GTX 1070 Strix  / CASE Evolv ATX Tempered Glass / SSD Crucial MX200 250GB / HDD  WD Black 1TB + WD Blue 3TB / PSU EVGA 750G2 / DISPLAYS 2x Dell U2414h / KEYBOARD Corsair K70 RGB Cherry MX Brown / MOUSE Logitech G602
Laptop: Dell XPS 15 / i7-6700HQ, 16GB RAM, 512GB SSD, GTX 960m, 1080P Display
Cheap Windows/Office Keys
BTW, get a friend to help you install the CPU cooler. It is pretty hard to do alone, unless you install it before mounting the mobo in the case (that was the mistake I made lol)
Could you send pics?
Main Rig
CPU: Ryzen 2700X
I love the orange. I'm just questioning wether it would look good with the rest of my build. What do you think?
Main Rig
CPU: Ryzen 2700X
different cooler, but other than that it's the same. Looks pretty awesome imo, so don't be concerned about looks.
This has made me want to go for a watercooler... the be quiet dark rock 3 will cover the ram and most of the mobo :(
Main Rig
CPU: Ryzen 2700X
21 minutes ago, momindo said:
i think watercooling is better for a k processor and looks better 9_9...+ you should get more wattage PSU if intend to do SLI in the future. ;)
Is the h100i any good?
Main Rig
CPU: Ryzen 2700X
yes actually in my opinion its the best watercooling unit..very solid but pricey.
i dont know much about watercooling but i red (and u should too) very positive reviews about the h100i..go for it.
