Yes. You seriously need an upgrade. I'd recommend the EVGA 750w G2
He who asks is stupid for 5 minutes. He who does not ask, remains stupid. -Chinese proverb.
Those who know much are aware that they know little. - Slick roasting me
AXIOM
CPU- Intel i5-6500 GPU- EVGA 1060 6GB Motherboard- Gigabyte GA-H170-D3H RAM- 8GB HyperX DDR4-2133 PSU- EVGA GQ 650w HDD- OEM 750GB Seagate Case- NZXT S340 Mouse- Logitech Gaming g402 Keyboard-  Azio MGK1 Headset- HyperX Cloud Core
Offical first poster LTT V2.0
https://linustechtips.com/topic/661066-help-with-psu/#findComment-8546930
I would upgrade to a higher quality power supply, yes. Something such as the EVGA SuperNOVA 550 G2 or the Corsair RM550x would do nicely.
'Fanboyism is stupid' - someone on this forum.
Be nice to each other boys and girls. And don't cheap out on a power supply.
CPU: Intel Core i7 4790K - 4.5 GHz | Motherboard: ASUS MAXIMUS VII HERO | RAM: 32GB Corsair Vengeance Pro DDR3 | SSD: Samsung 850 EVO - 500GB | GPU: MSI GTX 980 Ti Gaming 6GB | PSU: EVGA SuperNOVA 650 G2 | Case: NZXT Phantom 530 | Cooling: CRYORIG R1 Ultimate | Monitor: ASUS ROG Swift PG279Q | Peripherals: Corsair Vengeance K70 and Razer DeathAdder
https://linustechtips.com/topic/661066-help-with-psu/#findComment-8546952
No, the psu is fine.
4 hours ago, Rippey said:
Your PSU won't bottleneck anything other than maybe overclocking headroom. The main issue with the PSU is that it's outdated and "meh" quality wise
It has plenty of headroom already. It's not the best psu but a 6700k and 1080 doesn't pull that much power without an absurdly extreme oc.
Here's an oc'ed 6700k and 1080 pulling 330w from the wall and that's including the inefficiency of the psu. http://www.overclockersclub.com/reviews/nvidia_geforcegtx_1080_overclocking/7.htm
https://linustechtips.com/topic/661066-help-with-psu/#findComment-8548590
7 hours ago, Vikzer said:
Hey i have a corsair CX600 and a EVGA 1080 ftw card and a i7 6700k, i was wondering if my PSU needs a upgrade or not?
It's got enough wattage but you want a higher quality unit. An EVGA 650GQ is inexpensive and works well enough for your needs. The EVGA GS/GQ/G2/B2 are good choices for ya.
https://linustechtips.com/topic/661066-help-with-psu/#findComment-8549263
I think its an old CX. The exploding ones
AXIOM
https://linustechtips.com/topic/661066-help-with-psu/#findComment-8549265
CX psus don't just explode on a regular basis. There are bad units here and there and the reason why there are so many accounts of the psu failing is because of the sheer number of units sold.
https://linustechtips.com/topic/661066-help-with-psu/#findComment-8549407
They do have crap caps though. And inconsistent power iirc
AXIOM
https://linustechtips.com/topic/661066-help-with-psu/#findComment-8549413
