Netgear WPS problems?
Solved by desertcomputer,
On 9/15/2016 at 6:35 PM, Electronics Wizardy said:You have to use wps on your printer?
On 9/17/2016 at 6:35 AM, .spider. said:It's only a risk if it is on for more than ~1h
My router auto turn off WPS in one minutes anyways.
On 9/16/2016 at 11:21 AM, Donut417 said:Thats dumb. My HP printer just asks for the WPA password and connects.
My printer doesn't have interference on the printer.
I fix the problem, i went digging for the drivers of printer which allows me install via usb first and than setup through wifi. I also have to get wifi donge to connect my network. In the end i fix the problem.
