I want to take my RaspberryPI and 4 of my devices and create a device that makes those inputs in to a split-screen device could i do this? how?
Dendrotoxin
CPU: i5 6600k @ 4Ghz | GPU: Zotac AMP! 1070 @ 2GHz | RAM Crucial Balistix 2x4GB | PSU EVGA G2 750w | Cooler: NZXT Kraken x61 | Case Phanteks Eclipse P400s | Motherboard Gigabyte G1 Gaming Z170 | Storage: Toshiba 3TB HDD and MyDigitalSSD M.2 256GB
Perripherals
Keyboard(s) Razer Ornata Chroma, Razer Tartarus Chroma | Mouse: Logitech G502 Spectrum | Headphone: Audio Technica M40x | Monitor HP 22CWA
https://linustechtips.com/topic/660106-a-splitscreening-device-with-rpi/
4 minutes ago, Hackentosher said:
I don't think the rpi has a single video input, let alone four. Maybe a capture cared controlled by a pi?
could you direct me to a capture card that would do so
Dendrotoxin
Perripherals
https://www.xpra.org/trac/wiki/FakeXinerama
https://github.com/phillipberndt/fakexrandr
do you have or know anyone that has experience in using these
Dendrotoxin
Perripherals
Does any of the rpi's IO even have the bandwidth for video streams?
The Internet is invented by cats. Why? Why else would it have so much cat videos?
Idek, maybe if you overclocked a pi3, but I doubt it. Capture card is probably the best way to go, but I'm not sure if there's any out there (on a budget at least) that can take more than one video in.
ASU
Dendrotoxin
Perripherals
Just now, MrDrWho13 said:
I'm no expert, but I don't think the pi has either the I/O bandwidth nor the processing power to do this sort of thing.
someone already said that but thanks ive already recommended something else
Dendrotoxin
Perripherals
2 hours ago, VictorianReaper said:
Lol no.. The only remote chance of you getting this to work is as @Hackentosher said, get a USB capture card which would work on a rpi. I doubt there would be any though since the bandwidth required for those things are substantial. USB bus on the rpi is shared with every IO on the board except for GPIO.
From your posts I assume you are trying to use the rpi as surveillance camera machine (or whatever that's called)? Hate to break it to you but rpi is a poor choice for that. Unless you want to like.. plug in a few webcams with external power. Even so, the end results would not be great.
