Does this system need two GPUs?
Go to solution Solved by Castdeath97,
You can't run Fallout over 60FPS, so a single 1080 will suffice there and DOOM can run will with a in single 1080 in 100 frames, it's only hitman that may struggle to get over 100fps with one 1080 if you are going for high-ultra settings if I recall.
If you want to reply back to me or someone else USE THE QUOTE BUTTON!
Pascal laptops guide
Go single card 1080. Would say a good 1070 might even do the trick.
If possible always avoid dual GPU. Too many depends on support from creator and Nvidia drivers, and it might even underperform compared to single card.
The object of life is not to be on the side of the majority, but to escape finding oneself in the ranks of the insane.
Basic PC parts guide
PSU Tier list
A single 1080 should do you fine unless you want to go Titan X Pascal. 1080 would be more sensible.
Cor Caeruleus Reborn v6
CPU: Intel - Core i7-8700K
CPU Cooler: be quiet! - PURE ROCK
Thermal Compound: Arctic Silver - 5 High-Density Polysynthetic Silver 3.5g Thermal Paste
Motherboard: ASRock Z370 Extreme4
Memory: G.Skill TridentZ RGB 2x8GB 3200/14
Storage: Samsung - 850 EVO-Series 500GB 2.5" Solid State Drive
Storage: Samsung - 960 EVO 500GB M.2-2280 Solid State Drive
Storage: Western Digital - Blue 2TB 3.5" 5400RPM Internal Hard Drive
Storage: Western Digital - BLACK SERIES 3TB 3.5" 7200RPM Internal Hard Drive
Video Card: EVGA - 970 SSC ACX (1080 is in RMA)
Case: Fractal Design - Define R5 w/Window (Black) ATX Mid Tower Case
Power Supply: EVGA - SuperNOVA P2 750W with CableMod blue/black Pro Series
Optical Drive: LG - WH16NS40 Blu-Ray/DVD/CD Writer
Operating System: Microsoft - Windows 10 Pro OEM 64-bit and Linux Mint Serena
Keyboard: Logitech - G910 Orion Spectrum RGB Wired Gaming Keyboard
Mouse: Logitech - G502 Wired Optical Mouse
Headphones: Logitech - G430 7.1 Channel  Headset
Speakers: Logitech - Z506 155W 5.1ch Speakers
