I've overclocked plenty of times and i'm very familiar. I'm in the process of overclocking a 6600k and its a tuffy.
all of the cores will hit 4.3Ghtz perfectly. but when 4.4 hits... for some reason core #4 gets errors in  Prime95 and stops running that worker every time.
so I popped in the bios and for the first time i'm overclocking core-specifically, so i've got core #1 @4.4Ghtz, 2@4.8, 3 @4.8, and 4@4.3... or at least thats what i've set. CAM shows my cpu is running at 4.3Ghtz. CPU-z shows its running at 4.4.. so do you know of any program I can use to see core-specific speeds??
https://linustechtips.com/topic/656712-help-overclocking/
CPU-Z shows Core #0 by default. If you want to see the other cores, right click anywhere in the information window with the CPU tab selected.
https://linustechtips.com/topic/656712-help-overclocking/#findComment-8490885
do prime95 again but monitor all cpu temps. core, die etc. if one of them is significantly higher then its a temp isue, also make sure u have a decent power suply and a mobo with good voltage regulators for the cpu. the tiniest difference in power stability can cause your cpu to struggle.
https://linustechtips.com/topic/656712-help-overclocking/#findComment-8491481
