What are you gonna use it for? Just gaming or?
CPU: Intel Core I7 7700K & Corsair H100i v2
Mobo: Asus Maximus IX Hero
RAM: 32 Gigs @ 3000Mhz, Corsair Dominator Platinum
GPU: Asus Strix 1080 A8G
Storage: Samsung 840 EVO 500gb
PSU: Corsair HX750i
Case: Fractal Design Define S
https://linustechtips.com/topic/655631-first-pc-build/#findComment-8456039
For another $20 you can buy the m.2 version of that same SSD with twice the capacity (and ultimately TBW). That'll put the M.2 slot to good use and keep the case somewhat clean. besides the power supply being a bronze, good build.
[FS][US] Corsair H115i 280mm AIO-AMD $60+shipping
System specs:
Asus Prime X370 Pro - Custom EKWB CPU/GPU 2x360 1x240 soft loop - Ryzen 1700X - Corsair Vengeance RGB 2x16GB - Plextor 512 NVMe + 2TB SU800 - EVGA GTX1080ti - LianLi PC11 Dynamic
https://linustechtips.com/topic/655631-first-pc-build/#findComment-8456321
3 minutes ago, MrDrWho13 said:
Aha, here we go:
4 minutes ago, MrDrWho13 said:
Looks good, but I've heard bad things about the Corsair CX series power supplies. I can't remember the name of the power supply god though.
what's wrong with corsair's psu?
https://linustechtips.com/topic/655631-first-pc-build/#findComment-8456417
Bad components and max temp of 30C. I'd recommend EVGA G2 550w
https://linustechtips.com/topic/655631-first-pc-build/#findComment-8456599
http://pcpartpicker.com/list/6bJsLD
here is a much better overall system
MSI GE72 Apache Pro-242 - (5700HQ : 970M : 16gb RAM : 17.3" : Win10 : 1TB HDD : Razer Anansi : Some mouse) - hooked up to a 34UM58-P (WFHD) in dual screen
iPad Air 2 (for school)
iPhone 6
Xbox One Forza 6 Limited Edition Blue
https://linustechtips.com/topic/655631-first-pc-build/#findComment-8457424
