It's 40 still on steam but might try and get a cdkey
is it really good iv seen a lot of mixed reviews
what do u guys think ?
AMD (and proud) r7 1700 4ghz-
also (1600)
asus rog crosshairs vi hero x370-
MSI 980ti G6 1506mhz slix2 -
h110 pull - acer xb270hu 1440p -
 corsair 750D - corsair 16gb 2933
https://linustechtips.com/topic/655362-thoughts-on-dying-light/
It's got some fun mechanics, but only really comes to its right in coop. Plays sort of like Far Cry 3/4, but with zombies.
 c u r r e n t  /  ROG MAXIMUS Z690 FORMULA  /  I7-12700K  /  RTX 4090  /  32GB DDR5  /  LIAN LI PC-O11 DYNAMIC
 Z170 STINGER  /  6700K  /  TITAN X  /  32GB DDR4  /  NZXT MANTA  /  j u i c e b o x  build log
nohasslemods
https://linustechtips.com/topic/655362-thoughts-on-dying-light/#findComment-8435977
I'm sold if it plays like farcry !
also (1600)
https://linustechtips.com/topic/655362-thoughts-on-dying-light/#findComment-8436111
Even though im a big fan of the dead island series, dying light never was intresting to me for solo play, but with friends its an oke game
CPU:R7 5800X    Motherboard: asrock x470 taichi ultimate   RAM: 32GB G.Skill Ripjaws-V 2X16GB    GPU: Gigabyte GTX1080TI gaming oc 11g   Case: Corsair 600Q Storage: 1TB Samsung 870(boot), samsung 850evo 500GB, 2TB Corsair MX500, samsung 2TB 970 evo plus, WD 5TB black    PSU: Corsair AX860    CPU cooling: Corsair H105
https://linustechtips.com/topic/655362-thoughts-on-dying-light/#findComment-8436266
Dying light is great, especially with the following DLC. If you like zombie games then you will love it.
I7 4790K-----ASUS Z97-A-----GTX 1080-----CORSAIR H105-----CORSAIR VENGEANCE PRO 16GB-----ASUS PG278Q-----LOGITECH G900-----MASTERKEYS PRO L-----Sennheiser GSX 1000
https://linustechtips.com/topic/655362-thoughts-on-dying-light/#findComment-8460549
I got the enhanced edition
is that with the dlc ?
also (1600)
https://linustechtips.com/topic/655362-thoughts-on-dying-light/#findComment-8461403
yep. My steam I.D is lee-laa.
https://linustechtips.com/topic/655362-thoughts-on-dying-light/#findComment-8465555
Sept one- il "git gid"
step two- il ad you
also (1600)
https://linustechtips.com/topic/655362-thoughts-on-dying-light/#findComment-8466177
I just can't get past the shitty fov, so I still haven't left the home base
CPU i7 6700 Cooling Cryorig H7 Motherboard MSI H110i Pro AC RAM Kingston HyperX Fury 16GB DDR4 2133 GPU Pulse RX 5700 XT Case Fractal Design Define Mini C Storage Trascend SSD370S 256GB + WD Black 320GB + Sandisk Ultra II 480GB + WD Blue 1TB PSU EVGA GS 550 Display Nixeus Vue24B FreeSync 144 Hz Monitor (VESA mounted) Keyboard Aorus K3 Mechanical Keyboard Mouse Logitech G402 OS Windows 10 Home 64 bit
https://linustechtips.com/topic/655362-thoughts-on-dying-light/#findComment-8471258
It really depends if you're a fan of zombie games or not. If you are and you're looking to play this game solo, you'll also have a bad time. There are some caveats I have with the game such as losing XP upon death, (You can even de-level from this :/) being out during night gives you more XP to level up and spend points to git gud, but it is brutally hard at a beginner level. I'm about level 15 or so and I still can't handle it well by myself.
TL;DR it's fun but only with friends, level up survivor rank quickly to get a much needed item for traversal, don't bother doing missions at night until you are a much higher level.
https://linustechtips.com/topic/655362-thoughts-on-dying-light/#findComment-8473929
13 minutes ago, Quibiss said:
Spares you the cringe-fest that is the "story" and its "characters", you lucky man.
Meh, story is the least of my issues in games. Far cry 3 is one of my fave games and the story is ass. The game just has really good mechanics and is fun to play. Dying light looks like far cry with zombies and better crafting so I really want to play it. The fov fixes I've seen break your arms from your model and that is too immersion breaking for me.
https://linustechtips.com/topic/655362-thoughts-on-dying-light/#findComment-8474223
It's a great game imo, I had a lot of fun enjoying the story and just running around killing zombies and unlocking abilities.
  ﷲ   Muslim Member  ﷲ
KennyS and ScreaM are my role models in CSGO.
CPU: i3-4130 Motherboard: Gigabyte H81M-S2PH RAM: 8GB Kingston hyperx fury HDD: WD caviar black 1TB GPU: MSI 750TI twin frozr II Case: Aerocool Xpredator X3 PSU: Corsair RM650
https://linustechtips.com/topic/655362-thoughts-on-dying-light/#findComment-8474818
Whats up with the fov? It can be adjusted in game, or does it not go high enough for you maybe?
https://linustechtips.com/topic/655362-thoughts-on-dying-light/#findComment-8479544
The max fov is below what the minimum should be. Iirc, the max is below 80 and I prefer at least 90 and if possible 110. The game just feels cramped
https://linustechtips.com/topic/655362-thoughts-on-dying-light/#findComment-8479657
Which can easily be changed in the dying light level file.
It can be adjusted in the dying light  level file.Just like most other games.
Imo its def worth it. I don't often finish single player games .Dying light kept me entertained.Even if it is mindless zombie killing. Its by far one of the best zombie games.Now only if they made  a mode more like gta multiplayer.
https://linustechtips.com/topic/655362-thoughts-on-dying-light/#findComment-8479870
Thanks for all the responses it's downloading now
what kind of fps can I expect with sli 980tis ?
also (1600)
https://linustechtips.com/topic/655362-thoughts-on-dying-light/#findComment-8479909
You shouldn't have any problems with fps, though the view distance setting tanks the framerate and honesty doesn't make much of a difference when cranked up.
I play at 1440p max settings (apart from view distance) and fps ranges from 80-120 fps depending on where I am.
https://linustechtips.com/topic/655362-thoughts-on-dying-light/#findComment-8480096
Cool cheers man, so I can expect a bit more with sli then ? :)
also (1600)
https://linustechtips.com/topic/655362-thoughts-on-dying-light/#findComment-8480636
I would say so yes. I've never used SLI before though, not sure how well it works in this game either, my guess is it should be fine though.
https://linustechtips.com/topic/655362-thoughts-on-dying-light/#findComment-8480658
When i first heard my friend mention that he really liked this game i got so happy because i had heard about it and really wanted it. So the first thing i did when i got enough money was to buy the game for both of us, we installed it, and opened it. And then it all began! I had mixed up the names and all the times he was talking about what i thought was dying light, he was actually saying "Dead by daylight" which was the game i bought for us... So he got really happy and i got really disappointed.
This was 2 months ago and im still saving up for Dying Light
https://linustechtips.com/topic/655362-thoughts-on-dying-light/#findComment-8485160
Started it today it's awesome
also (1600)
https://linustechtips.com/topic/655362-thoughts-on-dying-light/#findComment-8485347
23 pound on g2a
also (1600)
https://linustechtips.com/topic/655362-thoughts-on-dying-light/#findComment-8485357
Super Fun in Coop. Smashing Zombie Heads with a Baseball bat is awesome.
CPU i7 6700k MB  MSI Z170A Pro Carbon GPU Zotac GTX980Ti amp!extreme RAM 16GB DDR4 Corsair Vengeance 3k CASE Corsair 760T PSU Corsair RM750i MOUSE Logitech G9x KB Logitech G910 HS Sennheiser GSP 500 SC Asus Xonar 7.1 MONITOR Acer Predator xb270hu Storage 1x1TB + 2x500GB Samsung 7200U/m - 2x500GB SSD Samsung 850EVO
https://linustechtips.com/topic/655362-thoughts-on-dying-light/#findComment-8497617
i LOVED the game...played through it entirely and i would rank it in my top 5 games for 2015
The night raids are the shit!
Can't wait for Dying Light 2
| CPU: Core i7-8700K @ 4.89ghz - 1.21v  Motherboard: Asus ROG STRIX Z370-E GAMING  CPU Cooler: Corsair H100i V2 |
| GPU: MSI RTX 3080Ti Ventus 3X OC  RAM: 32GB T-Force Delta RGB 3066mhz |
| Displays: Acer Predator XB270HU 1440p Gsync 144hz IPS Gaming monitor | Oculus Quest 3 VR
https://linustechtips.com/topic/655362-thoughts-on-dying-light/#findComment-8499369
