Hello everybody!
So for not a too long time ago, I upgraded my computer with a few new parts (6600k, Asus Z170 Pro gaming, 16 gigs of DDR4 Ram, New cooler)
And now I am planning on upgrading from 100mbps internet to 250mbps.
But will it do any change actually?
Because on the motherboard specs, it says (translated from swedish):
Wired Network: 10mbps / 100mbps / 1000mbps
So does this mean that it only support these 3? Or any between like 250mbps?
I am confused :P
Thanks ;)
Best regards,
olesien
(in real life name Linus xD)
https://linustechtips.com/topic/653695-motherboard-wired-network/
Id can use the link speeds of 10/100/1000
It doesn't have to use the full link, but thats the max speed.
For example if you connect you computer that is 10/100/1000 to a switch that can only do 10/100, it will connect at 100 as thats the fastest speed.
