Best Monitor to fit my Needs
Solved by Coombzy,
18 minutes ago, Cameronazzi said:(snip)
At that price point and IPS I recommend these three. Two of them are free-sync *perfect for your GPU* and IPS while the other one is simply a good 1440p IPS panel. I looked around for 60hz ones but there wasn't much price difference and their refresh rate is quite a bit.
(XG270HU also an option)
https://www.amazon.co.uk/MG279Q-Gaming-Monitor-Display-Freesync/dp/B00VH3HO6C
(If you want 60hz)
