Hello guys while installing my PSU a while ago i've just realised that i put the PSU fan face upside of my NZXT H440 case not the bottom.
Its been running like this for about 6 mounts now, should i turn it down or it doesn't matter a lot, it is more dust protected like that i think....
Regards!
- Redjo
Project Redline:
♦CPU: i7-5820k  ♦CPU Cooler: Kraken x61 ♦Mobo: MSI X99A SLI ♦RAM: G.Skill Ripjaws 4x4GB 3200mhz ♦GPU: Evga 980Ti Hybrid ♦Case: NZXT H440 ♦SSD: Samsung 850EVO 500GB ♦HDD: WD BLUE 1TB 7200rpm ♦Display: 1280 x 1024
https://linustechtips.com/topic/652957-psu-fan/
Regards!
- Redjo
it really doesn;t matter all that much. the only thing is that the PSU is now intaking hot air from your system rather then cold outside air.
https://linustechtips.com/topic/652957-psu-fan/#findComment-8384379
I can turn it down, just a bit lazy at the moment to un-plug all the cables then change it and re-plug....
>  So taking hotter air is bad thing?
>  Will it eat the PSU life? [If you know what i mean]
> Will it work more efficient with cold air?
Btw i think its really more protected from dust facing up, hmm
Project Redline:
https://linustechtips.com/topic/652957-psu-fan/#findComment-8384405
Fan side down: PSU will get cool filtered air
Fan side up: PSU will get hot air but can help exhaust your system's hot air
Desktop: i7-6700K / Asus Z170 S / H100i V2 / LPX 2400Mhz 16GB / 960 EVO 250GB / 2x 860 EVO 500GB / RM750i  / NZXT H440 XB271H + Z22n Monitors
Laptop: Thinkpad T450s / i7-5600U / 12GB / 860 EVO 500GB
https://linustechtips.com/topic/652957-psu-fan/#findComment-8384407
I have 3 exhaust 3 intake, with PSU exhausts become 4
Project Redline:
https://linustechtips.com/topic/652957-psu-fan/#findComment-8384417
In that case you should flip your PSU as it might cause negative air pressure and draw dust into the case
https://linustechtips.com/topic/652957-psu-fan/#findComment-8384423
You want the fan side down as the fan can't breath in an H440 if the fan is up. Regardless you want the fan down unless absolutely necessary to have it up for the sake of airflow.
https://linustechtips.com/topic/652957-psu-fan/#findComment-8385817
The H440 has the PSU cover so it wouldnt benefit airflow. I had it like that in my S340 and I had a mini heat attack :P
He who asks is stupid for 5 minutes. He who does not ask, remains stupid. -Chinese proverb.
Those who know much are aware that they know little. - Slick roasting me
AXIOM
CPU- Intel i5-6500 GPU- EVGA 1060 6GB Motherboard- Gigabyte GA-H170-D3H RAM- 8GB HyperX DDR4-2133 PSU- EVGA GQ 650w HDD- OEM 750GB Seagate Case- NZXT S340 Mouse- Logitech Gaming g402 Keyboard-  Azio MGK1 Headset- HyperX Cloud Core
Offical first poster LTT V2.0
https://linustechtips.com/topic/652957-psu-fan/#findComment-8385862
That's what I was saying. If the fan were up it wouldn't be able to really breathe.
https://linustechtips.com/topic/652957-psu-fan/#findComment-8385916
