If you have a 6500 you don't need the z170 go for a h170, or b150, the z170 is meant for overclocking which isn't available for the 6500.
 •E5-2670 @2.7GHz • Intel DX79SI • EVGA 970 SSC• GSkill Sniper 8Gb ddr3 • Corsair Spec 02 • Corsair RM750 • HyperX 120Gb SSD • Hitachi 2Tb HDD •
https://linustechtips.com/topic/652636-z170-series-help/#findComment-8381493
Wikiepdia search LGA 1151
https://en.wikipedia.org/wiki/LGA_1151
More USB ports
Either 1 ×16; 2 ×8; or 1 ×8 and 2 ×4 instead of 1 ×16
20 × 3.0 - PCH PCI Express configuration
RAID
Z is for overclocking a K branded CPU
CPU (multiplier + BCLK[13]) + GPU + RAM
as apposed to all other mobos
CPU (via BCLK[13] only;[14] might be disabled in new motherboards and BIOS releases[15]) + GPU + RAM (limited)
Plus Z motherboards cost more money honey!
https://linustechtips.com/topic/652636-z170-series-help/#findComment-8381498
