So i just got from my father an hp dv6500 yeah i know its kinda old but it still gets the job done i installed 2gb of ram and windows 10 32 bit i was wondering if an ssd would help with its constant slow down after some hours/minutes when i open applications any help appreciated
https://linustechtips.com/topic/652240-will-an-ssd-help/
Yes.. IMO SSD's are basically a required commodity in computers these days.
Community Standards
"Beast Mode"
Dedicated Streaming Rig
https://linustechtips.com/topic/652240-will-an-ssd-help/#findComment-8377544
Have you tried clean installing windows first?
https://linustechtips.com/topic/652240-will-an-ssd-help/#findComment-8377573
Have you tried to take the laptop apart and cleaned the fan and heatsinks for dust.
it is an older laptop and HP does has some heat problems when there is dust in the system and will get slow like hell.
plus while you are cleaning it, remove the old cooling paste and apply some new.
Main Machine:
Phanteks ENTHOO EVOLV • i7-6700K • Cooler Master Hyper 212 Evo • Asus Maximus viii Ranger • 16GB Corsair LPX 3000MHz • 2x EVGA GTX1070 • Samsung 970 EVO 1TB + 860 QVO 1TB + 4TB HDD • EVGA SuperNOVA 750 P2, 80 PLUS Platinum • 1x ASUS MG279Q 1x Samsung S27A350H 1x Samsung S27B750V • Xtrfy XG-K2-RGB • Logitech G502
Lan Machine:
Phanteks ENTHOO EVOLV ITX • i5-4460 • Stock Cooler • Asus H81I-PLUS • 8GB Kingston Hyperx Fury 1600MHz • Sapphire 290 TRI-X "OC" • A400 240GB SSD + 1TB HDD • Corsair CX650M
Main Server:
Unraid 6.8.3 • Inter-Tech IPC 4U-4424 • ASUS PRO WS X570-ACE • Ryzen 9 3900X • 32GB DDR4 • 4TB Parity • 20TB Array total • 2x 240GB SSD Cache
Nas Server:
Unraid 6.8.3 • Silverstone DS380 • Asrock Q2900-ITX • Pentium J2900 • 4GB DDR3 • 3TB Parity • 5.5TB Array total
https://linustechtips.com/topic/652240-will-an-ssd-help/#findComment-8377631
An SSD will definitely make some things faster, but I'm not sure upgrading to one will help the kind of performance issues you are seeing. The laptop slows down after opening applications, which makes me think that the issue might be due to running low on RAM and applications are starting to use swap space (essentially RAM overflow that's on the hard drive--and no, an SSD will not make swap appreciably faster). It's pretty easy to use 2gb of memory with one program nowadays. I would check task manager if you haven't already to see how much memory is being used. Upgrading that to 4gb (if you can) would definitely help.
Another thing that others have suggested would be to clean the laptop. It could be thermal throttling as well.
Main rig specs: i5-6500 (3.2 GHz), Cryorig H5 Universal, EVGA GTX 970 FTW+, 16GB Corsair Vengeance DDR4 (2133MHz), Asus Z170i Pro Gaming, Samsung 950 PRO 256GB, Phanteks Enthoo Evolv ITX, LG 3440x1440 Ultrawide.
https://linustechtips.com/topic/652240-will-an-ssd-help/#findComment-8377663
that would not be an ssd that is from the components thermal trotting to save themselves from too much heat doing what Las_Killar suggested should fix it. A ssd will help speed it up overall but having a hdd is not the reason for the problem. also what Mr_flynn stated about the ram limitations could be it also
https://linustechtips.com/topic/652240-will-an-ssd-help/#findComment-8377670
