Hi guys, I'm currently purchasing and budgeting for a brand new build and am wanting to share it with you to see if the parts I've chosen are gonna suit me well in your expert (I hope) perspectives. I've done endless hours of research into each of the parts in order to not have a shitty build like my current system, and ensure it is fully optimised for the likes of 4K and RAW + ProRes!
CPU:  Intel Core i7-5820K 3.3GHz 6-Core Processor
CPU Cooler:  be quiet! Dark Rock Pro 3
Motherboard:  ASRock X99 Extreme4 ATX LGA2011-3 Motherboard
Memory:  Kingston HyperX Fury Black 32GB (4 x 8GB) DDR4-2666 Memory
SSD:  Samsung 850 EVO-Series 500GB 2.5" Solid State Drive
HDD:  Western Digital Blue 2TB 3.5" 5400RPM Internal Hard Drive
GPU:  Asus GeForce GTX 970 4GB STRIX Video Card
Case:  NZXT H440 (Matte Black) ATX Mid Tower Case
PSU:  EVGA 600W 80+ Certified ATX Power Supply
Extra Case Fans (Top Mounted): Corsair Air Series AF-120 White 2 Pack
Just to let you know I already have the GTX 970 and the PSU in my current build and would transfer them over. And have already bought the 5820k which peeps over my monitor at me, constantly reminding me to never spend and SAVE.
PC Specs:
CPU: Intel i7 5820K  GPU: NVIDIA RTX 3070 (FE)  Motherboard: ASRock x99 Extreme4  PSU: Bequiet! Powerzone 650W  RAM:  32Gb DDR4 Crucial Ballistix Sport LT (white) 2400mhz  CPU Cooler: Bequiet! Dark Rock Pro 3  Storage: 1x Samsung 850 EVO 500gb SSD, 1x WD Blue 2tb HDD 5400rpm, 1x Toshiba 500gb HDD  Case: NZXT H440 (matte black w/ case fans)  Case Fan (Top Mounted): Notcua AF-14 144mm  LED Lights: TOP LED 2x30 Strips
Peripherals:
Speakers: M-AUDIO AV-42 (pair)  Headphones: AudioTechnica ATH-M20X,  Keyboard: AULA 859  Mouse: Tecknet  Microphone: RODE NT1-A  Audio Interface: ZOOM R8
Camera Specs:
Cameras: BlackMagic Pocket Cinema Camera, Canon 4000, Olympus OM-1, Zorki 4  Lenses: Olympus OM-1 Zuiko Macro, Regular and Telephoto, EFS 18mm-55mm, MFT 12mm, 25mm and 35mm, 50mm Jupiter 8, 50mm EFS
Software:
Editing: BlackMagic Davinci Resolve, Adobe Premiere Pro, Adobe After Effects, Sony Vegas Pro, Adobe Photoshop, Adobe Lightroom, Cubase LE AI Elements 6, Adobe Elements
Phone: Pixel 4
https://linustechtips.com/topic/651800-ultimate-budget-editing-pc-help/
I am nowhere near sure but I guess if you can find some deal on a used server with a more then 6 core xeon (and I have seen them go for absurdly low prices compared to what you proposed) you might be better of but I don't know exactly if that is the better idea.
http://linustechtips.com/main/topic/334934-unofficial-ltt-beginners-guide/ (by Minibois) and a few things that will make our community interaction more pleasent:
1. FOLLOW your own topics        2.Try to QUOTE people so we can read through things easier
3.Use
PCPARTPICKER.COM - easy and most importantly approved here        4.Mark your topics SOLVED if they are
Don't change a running system
6 minutes ago, AlisterMultimedia said:
Pictures not working btw.
3.Use
Refresh page
PC Specs:
Peripherals:
Camera Specs:
Software:
Phone: Pixel 4
 Most of the time a 5820 will be faster than a 8 or 12 core xeon as most editing software likes clock speed as well as cores.
good to know, well i tried.
3.Use
Electronics Wizardy is right. I will also prefer you going with the i7 6 core processor rather than going for a 8 core xeon. The only thing you can improve in this build is the gpu, go for 1060> It is faster than 970 and has more memory too. The power supply you choose is more than enough. You can go with a 500W gold certified power supply.
Good advice. I will eventually buy a 1070, but my 970 has been with me less than a year so I want to make good use of it first. The power supply I already currently have, but may invest in a better certified one.
PC Specs:
Peripherals:
Camera Specs:
Software:
Phone: Pixel 4
