i have the problem of my screen not fitting propperly. when on  the intel hd530 drivers i would rescale the aspect ratio but now with the AMD software i don't know how to fix that issue. please help. thanks
Cor Caeruleus Reborn v6
CPU: Intel - Core i7-8700K
CPU Cooler: be quiet! - PURE ROCK
Thermal Compound: Arctic Silver - 5 High-Density Polysynthetic Silver 3.5g Thermal Paste
Motherboard: ASRock Z370 Extreme4
Memory: G.Skill TridentZ RGB 2x8GB 3200/14
Storage: Samsung - 850 EVO-Series 500GB 2.5" Solid State Drive
Storage: Samsung - 960 EVO 500GB M.2-2280 Solid State Drive
Storage: Western Digital - Blue 2TB 3.5" 5400RPM Internal Hard Drive
Storage: Western Digital - BLACK SERIES 3TB 3.5" 7200RPM Internal Hard Drive
Video Card: EVGA - 970 SSC ACX (1080 is in RMA)
Case: Fractal Design - Define R5 w/Window (Black) ATX Mid Tower Case
Power Supply: EVGA - SuperNOVA P2 750W with CableMod blue/black Pro Series
Optical Drive: LG - WH16NS40 Blu-Ray/DVD/CD Writer
Operating System: Microsoft - Windows 10 Pro OEM 64-bit and Linux Mint Serena
Keyboard: Logitech - G910 Orion Spectrum RGB Wired Gaming Keyboard
Mouse: Logitech - G502 Wired Optical Mouse
Headphones: Logitech - G430 7.1 Channel  Headset
Speakers: Logitech - Z506 155W 5.1ch Speakers
What monitor and what cable do you use?
Can you get the model number off the back?
Is there a button for auto adjustment?
Unfortunately HDMI doesn't support 1080p on this monitor.
Haven't used an AMD card in a long time so my usefulness may be lacking.
Can you open Catalyst?
Just now, PlayCrackTheSky said:
If you just want to adjust the scaling...right click and open Radeon Settings>Display>GPU scaling...turn on and select desired scaling mode.
That causing issues with other programs.
Can you show him/her how to put the resolution to 1080i?
you have lost me now. remind me, what is catalyst i am not sure. and are you sure that my tv can't do 1080p over hdmi because whenit turns on it tells me it is running 1080p 60hz in the top right of my screen
the model number in the url of the mannuel you linked is L19digb10, where as the model number for my tv was l22dvdb10 like i said
5 minutes ago, TimBoBaggins said:
gpu scaling for me only has two stages. on or off. no adjustmen. no drop down box or anything
What version of crimson are you using?
It doesn't have the Scaling Mode tab to the right of it?
It's the same manual for both models. Same thing happens with many LG monitors.
4 minutes ago, TimBoBaggins said:
doesnt explain why the tv software tells me i am running in 1080p though. i will try get a picture to show you
If you see the asterisk below the chart it states that the monitor will scale the image. Do you have any settings to change the pitch in the monitor's menu?
no there is no pitch. but there is h and v position. but it oly moves the whole thing up and down or left to right. instead of scaling the screen
Can you open the AMD Catalyst software? @PlayCrackTheSky Do you mind helping me out if you know how to use Catalyst?
Right-click on the desktop.
