So I've got two questions about corsair.
1) If i want to overclock a 6700K to about 4.5ghz or 4.6ghz will a h80I be enough to handle the heat or will something like a h100I be needed?
2) I've always been nervous about getting an AIO water cooler if a leak or break occurs. despite hearing a 0.5% chance of this happening im still nervous about it. However i have heard that corsair replaces any parts broken due to the water cooler breaking. I want to know if this is true or if this policy still stands
Thanks
https://linustechtips.com/topic/650464-corsair-water-cooling/
1. Yes, but only if you use it as an intake, otherwise the heated up air causes high temperatures. Still, for my personal preference, a 240 or 280mm is better. However, a high end air cooler performs just as good, if not better.
2. They shouldn´t break. If they do, Corsair replaces them no problem
CPU: AMD Ryzen 9 5950X PBO GPU: Asus Strix RTX 3090 OC Mobo: Gigabyte X570 Aorus Master RAM: 32GB G.Skill Trident Z RGB 3600Mhz CL17
CPU Cooler: Corsair H150i Capillex Storage: Samsung 980 Pro and 970 Evo 1TB Samsung 860 EVO 1TB Crucial MX300 525GB WD Black 2TB PSU: Corsair HX1000 Case: Corsair 500D SE RGB 6x LL120
https://linustechtips.com/topic/650464-corsair-water-cooling/#findComment-8359738
Thanks
Although this does depend on the silicon lottery, you should be able to do that even with basic air coolers like the hyper 212. It possible for a leak to happen, just very unlikely if you are careful. I wouldn't recommend getting AIO water, high end air will perform better for the same price.
Please quote our replys so we get a notification and can reply easily. Never cheap out on a PSU, or I will come to watch the fireworks.
PSU Tier List
My specs
PC:
CPU: Intel Core i5-6600K @4.8GHz
CPU Cooler: Noctua NH-U14S
Motherboard:  ASUS Maximus VIII Hero
GPU: Zotac AMP Extreme 1070 @ 2114Mhz
Memory: Corsair Vengeance LPX 16GB (2 x 8GB) DDR4-2400
Storage: Samsung 850 EVO-Series 500GB
Storage: Western Digital Caviar Blue 1TB
Case: Cooler Master MasterCase Pro 5
Power Supply: EVGA 750W G2
Peripherals
Keyboard: Corsair K70 LUX Browns
Mouse: Logitech G502
Headphones: Kingston HyperX Cloud Revolver
Monitor: U2713M @ 75Hz
https://linustechtips.com/topic/650464-corsair-water-cooling/#findComment-8359740
Thanks
Id prolly save a lil more and go for the H110i V2 if you have the room in your case or fine a 2nd hand one h100i. They are generally pretty reliable.
Main system:
i7 6700k @4.8ghz 1.45v
ROG Maximus Hero VIII
Gigabyte G1 980ti Sli @1500 ghz
Samsung 950 pro 512gb
16gb G.Skill Ripjawz V @3400mhz
Corsair H115i 280mm AIO
Corsair 400c Case
Corsair RM1000i
Backup/Older/Toys:
Intel i3 6100 @4.6ghz 1.52v
Asrock B150M Pro4/Hyper
Intel 750 series 400gb
Radeon Rx 470 XFX
Thermaltake Water 3.0 360mm AIO
inWin 303 case
AMD Phenom II x4 940 @3.9ghz 1.65v
Gigabyte 780g mobo
Corsair H100 240mm AIO
Corsair Dominiator 8gb DDR2 @1066
Evga GTX 750ti FTW @1450mhz
Thermaltake Matrix case (modded)
"The best way to look stylish on a budget is to try second-hand, bargain hunting, and vintage"
https://linustechtips.com/topic/650464-corsair-water-cooling/#findComment-8359745
