So i'm tryinh to help my cousin out with her old Macbook Late 2009 running OSX 10.8
before i took it home, she formatted the drive with the Disk utility, powered the Machine off and gave it to me
upon arriving home i power on the machine to find a white screen with a folder and a question mark on it
Holding command + r just white screens forever.
holding C shows the recovery disk on screen and an arrow pointing to it, i click on the arrow and the system white screens endlessly.
any help?
Rigs I've Built
The Striker i5 4590 @ 3.7 ||  MSI GTX 980 Armor X2 || Corsair RMX 750 || Team Elite Plus 8 GB || Define S || MSI Z97S SLI Krait
The Office PC i3 4160 @ 3.6 || Intel 4600 || EVGA 500B || G.Skill 8 GB || Cooler Master N200 || ASRock H97M Pro4
The Friend PC G3258 @ 4.3 || Sapphire R9 280X Tri-X || EVGA 600B || 8 GB Dell Ram || Cooler Master N200 || ASRock H97M- iTX/ac
The Mom Gaming PC A10-7890K @ 4.4 || iGPU + ASUS R7 250 ||  8 GB Klevv DDR3-2800 Mhz
https://linustechtips.com/topic/650289-macbook-help/
Just now, suchamoneypit said:
She formatted the drive the OS was running on?
yes. to clear her files. but left the recovery partition
the partition with the OS was cleared
Rigs I've Built
https://linustechtips.com/topic/650289-macbook-help/#findComment-8358216
Clean install the OS?
https://linustechtips.com/topic/650289-macbook-help/#findComment-8358229
i have only ever done that with windows. how do i go about that on a mac?
Rigs I've Built
https://linustechtips.com/topic/650289-macbook-help/#findComment-8358238
http://mashable.com/2015/10/01/clean-install-os-x-el-capitan/#9_HQ8Vc7pEq0
https://linustechtips.com/topic/650289-macbook-help/#findComment-8358250
5 minutes ago, Enderman said:
where do i get a El capitan file?
i dont exactly have another mac lying around
Rigs I've Built
https://linustechtips.com/topic/650289-macbook-help/#findComment-8358278
Idk, I don't use apple.
https://linustechtips.com/topic/650289-macbook-help/#findComment-8358294
I had a similar issue on a more current mac- I deleted a windows partition off my mac and it screwed up the hard drive. I just took it into the Apple store and they reinstalled the OS and wiped the hard drive, as I suspected was necessary. It was free of charge so if you can't seem to fix it that may be your best option :/
https://linustechtips.com/topic/650289-macbook-help/#findComment-8368650
