If it only has USB 2.0 ports on it then why would you care about it plugging into USB 3?
https://linustechtips.com/topic/649018-usb-hub/#findComment-8346836
2 minutes ago, fiberzs is dad said:
the mobo im looking at only has usb 3 but some of my peripherals use usb 2.0
You don't need a USB 3 connection to plug into a USB 3 port...
USB 2 and 1 are also compatible and will work fine.
https://linustechtips.com/topic/649018-usb-hub/#findComment-8346853
