HELP MOBO PANIC
Go to solution Solved by Andster29,
As a last measure, just take it and unplug everything. Let it sit for a day with no power in it at all. When you do RMA the board, call ASUS directly and play dumb. Emailing them takes an eternity and a half. Just call, get it done in a hour and don't give away what you did. Tell them it just stoped working. It will cost like $10 to ship. Yes I know it sucks, but better than getting a brand new board. Use the box the board came in to ship it to them. Not the full box , but the smaller one the the board was physically in.
SO I am really freaking out right now. I just got an LED strip for my case, and the one of the strips managed to hit my Asus Z97-AR mobo. It was only on there long enough to restart the system. It made a bad smell and a little bity spark direcly on the board. I don't have a mobo speaker. It boots just fine except there is no display. I reinstalled both my 970 and Ram, and I even tried the onboard graphics. No screen whatsoever. Please help.. I am only 14 so my computer is literally the only physical thing I have besides my laptop and phone. Its estimated worth is $1500. Thanks
My System:
Intel Core i5-4690k  / Cooler Master Hyper 212 Evo Asus Z97-AR MSI Nvidia GeForce GTX 970 100me Corsair Vengeance LP 1600Mhz 2x4GB DDR3 Samsung 850 EVO 250GB / Seagate Barracuda 1TB 3.5" 7200RPM HDD / NZXT S340 EVGA SuperNOVA G1 650W / Windows 10 Home 64 / AOC G2460PQU 1080p 144hz / Corsair VOID Wireless RGB Razer Taipan Laser Razer Blackwidow Ultimate 2014
My Laptop (Asus X55C-DS31):
Intel Core i3-2370M @ 2.4Ghz 6GB RAM / OCZ ARC100 240GB SSD /
My Phone:
OnePlus Three Graphite Black / 64GB
My Watch:
Moto 360 1st Generation
https://linustechtips.com/topic/648886-help-mobo-panic/
All lights turn on, the on off switch is fully funtcional. the fans spin, even on the 970, the CD drive turns on. just no display.
My System:
My Phone:
My Watch:
https://linustechtips.com/topic/648886-help-mobo-panic/#findComment-8345415
Did you make sure all connections are secure? Also..make sure that your monitor is still plugged in. Hope it's only a little situation that can be easily fixed.
1 minute ago, Verrierr said:
Do you have another display device you could try connecting your rig to?
Try this.
https://linustechtips.com/topic/648886-help-mobo-panic/#findComment-8345432
Everything is secure, but I will try another display. There is no physical damage (no burns).
My System:
My Phone:
My Watch:
https://linustechtips.com/topic/648886-help-mobo-panic/#findComment-8345441
Different ram, different dispaly, different display cable. no output on onboard.
My System:
My Phone:
My Watch:
https://linustechtips.com/topic/648886-help-mobo-panic/#findComment-8345463
This is why you turn your PC off and unplug it before changing things...
https://linustechtips.com/topic/648886-help-mobo-panic/#findComment-8345500
I did. the led strip fell on the motherboard.
My System:
My Phone:
My Watch:
https://linustechtips.com/topic/648886-help-mobo-panic/#findComment-8345507
Just now, AriCode said:
It made a spark even when the entire PC was off and unplugged? Were you using some obscure RGB lighting strips?
THe pc was on when it hit. The led strips had a metal connector on the end that was apparently outputting electricity and that hit the board. I swear if i lose this computer...
My System:
My Phone:
My Watch:
https://linustechtips.com/topic/648886-help-mobo-panic/#findComment-8345538
removed the cmos battery. no change
My System:
My Phone:
My Watch:
https://linustechtips.com/topic/648886-help-mobo-panic/#findComment-8345580
Tried moving the GPU into another PCi-Express slot? while you said you tried onboard, you tried that after removing the 970?
PC - NZXT H510 Elite, Ryzen 5600, 16GB DDR3200 2x8GB, EVGA 3070 FTW3 Ultra, Asus VG278HQ 165hz,
Mac - 1.4ghz i5, 4GB DDR3 1600mhz, Intel HD 5000.  x2
Endlessly wishing for a BBQ in space.
https://linustechtips.com/topic/648886-help-mobo-panic/#findComment-8345592
yeah. Will try that.
My System:
My Phone:
My Watch:
https://linustechtips.com/topic/648886-help-mobo-panic/#findComment-8345599
11 minutes ago, AriCode said:
How did the RGB strip hit the MOBO? It just fell off? Was it glued onto the inside of the case or was it a magnet connection?
It was resting on the side of the case. completely my fault it fell.
My System:
My Phone:
My Watch:
https://linustechtips.com/topic/648886-help-mobo-panic/#findComment-8345690
7 minutes ago, AriCode said:
You didn't even secure it? Dude...
I wasn't going to put it that case. I just seeing if it worked , and get an idea what it would look like. I am so screwed.
My System:
My Phone:
My Watch:
https://linustechtips.com/topic/648886-help-mobo-panic/#findComment-8345751
Take a couple of deep breaths. Try everything one step at a time. Never try to do multiple steps at once. Take another the monitor and try hooking it up to your laptop. This will see if the monitor is still working.  Next: take your system to the basics (GPU out, no keyboard or mouse, unplug everything except the display). Try turning it on plugged into the onboard graphics. If that works, plug everything in one item at a time.
https://linustechtips.com/topic/648886-help-mobo-panic/#findComment-8345827
Pretty sure its done. I cannot test the other hardware. I tried the SSD so I am sure the HDD is fine to. Would anyone know if a short circuit affects your CPU/GPU/ or RAM? Is there any way to repair it?
My System:
My Phone:
My Watch:
https://linustechtips.com/topic/648886-help-mobo-panic/#findComment-8346066
https://linustechtips.com/topic/648886-help-mobo-panic/#findComment-8346106
